Tire Pressure recommendation (1 Viewer)
After a more thorough search of the online manual I found this. Since I am not in the EU it looks like my vehicle is rated at 33 psi with the stock 116 load index tires.
Well, i think that makes it similar to the USDM spec. So 43 PSI would be the RCTIP.
Hi there @gaijin , what would be the tire pressure recommendation for 2017 LC with BFG KO3 285/70R17 126S. TIA
If those are the LT285/70R17, then the RCTIP for them on your LC200 is 40psi F/R.
HTH
@gaijin what would my pressure be on LT285/65/18 Ko2’s on my 2016 Land Cruiser? Thank you so much
The RCTIP for LT285/65R18 tires on your LC200 is 42psi F/R.
HTH
What would the recommended tire pressure be for the Lexus LX 600 with BF Goodrich KO2 265/65/R18 122R E1. Thank you in advance.
Hello,
What would the recommended cold tire inflation pressure be for
285/75/r17, 128/125S, E rated BFG KO3 be on a 2016 LX 570
Thanks in advance!
What would be the tire pressure recommendation for Falken Wildpeak AT3W LT285/55/R20 122/119T Load Range E?
Thank you!
Master @gaijin could I get the RCTIP for falken wildpeak at4ws in 285/70/18 117S C1 on my 2013 200 series? Thank you.
Sure!
The RCTIP for those LT285/70R18 tires on your LC200 is 38psi F/R.
HTH
Tire pressures for General Grabber A/TX P 275 /70 R18 116S SL please.
No P-Metric tires that size listed by the manufacturer.
Do you mean this ISO-Metric tire?
And I need to know what vehicle you are planning on mounting these.
