Tire Pressure recommendation
@gaijin can you help me out with RCTIP for Michelin Defender LTX M/S2 285/65/R18 XL (not E load!).l? Stock LC, normal load.
Thank you!
Thank you!
Assuming you mean the
MICHELIN® DEFENDER® LTX® M/S 2 285/65R18 116T XL BSW​
The RCTIP for those ISO-Metric 285/65R18 116T XL tires on your LC200 is 38psi F/R.
HTH
@gaijin Wow, your input is incredible and appreciated. If you have a paypal, please post it
After an outright rabbit hole of research I am still not sure on what I should be running. Can you please give your suggestion?
285/60R18 120S XL
Toyo AT3
2020 LC Heritage
285/60R18 120S XL
Toyo AT3
2020 LC Heritage
Thanks for the kind words, always happy to help.
The RCTIP for those ISO-Metric 285/60R18 120S XL tires on your LC200 is 33psi F/R.
HTH
a quick search didn’t pull up the Yokohama Geolander M/T G003 37x12.5R17 LT 124Q 8pr under an 08’ LX570
@gaijin could you kindly give us that recommendation?
Thank you!
Mr @gaijin ,
Would you please let me know what the recommended tire pressure for the LT285/65R18 E/10 125/122S Falken WILDPEAK A/T3W on a stock body (but lifted) 2013 LC200 (on Tundra 8x18 take offs)?
Also, I see that many of the recommended tire pressures are in high 30s if not low 40s. Why so high?
Back in the days I owned a Rubicon on 315/70/17 KO2s and I would run around 33 psi which some thought was a little high.
Is it simply the weight difference of the 200 series that makes it so that higher psi is needed?
Thank you!
Mr @gaijin ,
Thank you!
The RCTIP (Recommended Cold Tire Pressure) for those LT285/65R18 Load Range E tires on your LC200 is 42psi Front/Rear.
Here's a link to an excellent monograph on tires and pressures published by Toyo Tires: Guidelines for the Application of Load and Inflation Tables
That should answer your questions.
HTH
Falken Wildpeak R/T01 285/75R17 C1 load on 2019 LC200. @gaijin if I used the calculator I have the RCTIP as 37 to 38psi. Am I in the right range?
You are indeed in the right range! Well done.
The RCTIP for those LT285/75R17 tires on your LC200 is 37psi F/R.
HTH
HTH
thank you for the confirmation.
Thank you!
What about little ol’ me 🥺 @gaijin 😉
Thank you!
Your use case is so far outside the normal operating conditions for the LX570, that I am not confident in giving a RCTIP.
My best personal recommendation is to try various tire pressures between 25psi and 35psi until you find one that works best for your particular use case. As far as safety goes, anything above 25psi is OK, but on road handling may suffer.
Sorry I can't be more definitive.
HTH
HTH
Ok. I understand.
So asking about the Mickey Thompson 42X13.50R17LT also under an 08’ LX is probably out of the question 😆
Ok. I understand.
Yeah... I only have data for the 42x14.50R17LT... ¯\_(ツ)_/¯
The other one is there new 42” Baja Boss M/T just released 👌🏼
My recommendation would still be the same - anything above 25psi so the tire doesn't overheat on the highway, and whatever pressure above that to make you happy with your particular use case. Trying to find an "ideal" or "correct" tire pressure for everyday use with these tires would be an exercise in futility - everybody would be different.
@gaijin
I need to replace TPMs sensors (hopefully just sensors n not system).
I went to Costco and the have their own wheel sensors; DiII. I haven’t gone to Americas tire yet which is where I’ve always gotten my tires so not sure what sensors they install.
From research looks like 2013 LC200 OEM is pacific.
Do I need to do TPMS replacement at dealership or would it be fine at one of the tire stores or even Costco?
TIA
