Tips Requested for Engine Wiring Harness Removal and Refurbishment - 1994
clx16
Alpharetta GA
I wonder how hard it is to get toyota color coded wire on spools. I wouldn't mind a source so that I can make good repairs or replacements when it comes to wiring harnesses.
east coast Canada
Getting 2 colour coated wire is not difficult, getting 3, such as the dot colours on some Toyota wires, can be a challenge.
OBX North Carolina
You could try and find a few used wire harnesses from part outs and mash the good parts form them all to make one good one. Buy the few connectors you may need new. Make sure you get a the tool to pull the pins out of the connectors. Here's a thread I found about the tools Great Terminal Pin Removal Tool for 80 Series - https://forum.ih8mud.com/threads/great-terminal-pin-removal-tool-for-80-series.885132/.
Also if you need to use new wire seek out Automotive wire rated for engine bays.
I have a 96 so the OEM wire harness was still available. I went with that because the cost of buying new connectors and pins I needed individually was going to cost almost as much as a whole new harness from Toyota. My wire harness was in really bad shape.
Sisters, OR
Well the hood is open... Haven't dug in just yet though.
Sisters, OR
Tore into it today, making some progress. Called it a day when I tried to pull the upper intake manifold but its still stuck somewhere. I couldn't manage to pull the harness up through the bottom of the intake manifold so hopefully removing the upper portion will make it easier.
Lots of brittle clips (especially on the injectors) that snapped upon removal.
alia176
Tijeras, NM
I'm late to the party but here's my $.02 worth. The engine has reached senior citizen status and needs a boat load of stuff to be done. I'd say, acquire parts over time until you've amassed a sizeable pile of parts then yank the engine. Do all PMs needed, including the HG, if needed. You can pull the wiring harness with the engine rather easily and separate it and work on it leisurely. This assumes this 80 isn't your DD. While the engine is out, you can also do the rear main seal, tranny input seal, motor mounts and a host of other services.
