Ticking time bomb TICK TICK TICK: Spark plugs Alert Alert Alert! (9 Viewers)
For reference when I replaced my plugs a coil a year and a half ago I torqued to 13 ft lbs and a few weeks ago I checked them and all but one or 2 were a small bit loose. Needless to say I torqued them more...
Bumping this to the top. Tightened my Denso iridium’s about six months ago to 13lb/ft and the ticking stopped. The ticking gradually came back so I changed them all this week with ngk ruthenium. Four were loose again so I torqued to 18ft/lb. Replaced the seals, boots, and springs on the four loose coils. Five of the plugs had scorching.
Just replaced the plugs on our new (to us) JDM 100. None were terribly tight—very easy to break loose. Two (cylinders 4 and 6, with 4 being the worse of the two) were not tight at all and the coil boots on those two had started to brown, so they were clearly not sealing well. Pic is of the #4 plug and coil boot.
Vehicle has just about 70k miles on it—these (Denso VK20) were probably the original plugs.
All that to say glad I did this very soon after purchasing!
#4 & #6 are the two, I find loosen the most. #3 & #5 second most.
The factory installed Denso plugs, always say made in Japan. All I see today, purchased in USA from Denso distributor. Say: Assemble in USA. I did once buy a set of Denso, came by way of Mexico based on packaging. They also said made in Japan. I begged seller for more. No Mas!
I like to blow off loose sand & dust, even washes engine or before beginning. You must take care not to get any dust into heads. I also use an air pistol, to blow out spark plug tube, before removing plug.
Here a few pictures that may be helpful.
Air box removed reveals RH plugs #'s 8, 6, 4 & 2 (#2 front of engine).
Plugs #1, 3, 5, & 7 (#7 rear by fire wall) are accessible once fuel bracket removed.
Two 10mm bolts secure the fuel bracket that's in the way.
To remove coil pinch at top to release catch and pull off. I use a needle nose pliers to pinch and pry off with a wide blade screwdriver between bottom of wiring housing block & coil or a hook like screw driver to pull off. This must be done very very very gently or you will break the tab of clip or wire housing. Just take your time and go easy, they can get stuck from dirt jammed in it.
Once coil out. Use compressed air, to blow dust out spark plug tube.
Here is and example of coil boot premature aging from heat. Notice the two brown boots compared with the one good gray one.
The brown boot indicates prematurely aged. Can be seen cracking when squeezed and are no longer soft and pliable. Denso sell a boot& seal kit. Which I use with spark plug changes. Number one concern, even if they look good. Is the top seal. It keeps dust out, and water from washing in sand/dust.
Ok, I have been searching every variation, with the coil part number and any other keywords I can think of....but you have a part number for this "boot and seal" kit?
After about 1 year after initially installing new plugs, I decided for my pre road trip check list, to check the torque. 2 were kinda hand tight, 4 were tight but got more from them, and 2 were snug even though I gave them a tiny bit more.
See this is what makes a good mod a great mod. Thanks @Trapper50cal. I actually bookmark many of @2001LC threads because they’re so thorough, and I had a vague memory of there being a cautionary tale around plugs, but I couldn’t remember. Thanks for pointing me the right way.
Not a mod but thanks for the compliment just the same. I just remember having to use a breaker bar to get my plugs out and sweating bullets that I wouldn't bugger up the threads in the head...scary stuff. Don't want that befalling anyone else if it can be avoided.
I had one took 3 tank full of gas w/44K and 3/4" breaker bar. I too was sweating bullets. It wasn't the time I'd seen where anti seize was used on threads (bad idea). They walkout, and as the hot combustion gasses cooks anti seize, hardening and caking in threads.
lol you’re everywhere here so just assumed 🤣
I re-removed the ones I torqued to 13, wiped off the anti-seize, and put just a drop of motor oil on the threads instead. When fully dry, they really gall. Maybe new ones don’t, but I figure a drop of oil won’t cook like anti seize on mine, which have about 45k on them and look serviceable.
Torqued back in to 18, as you suggested @2001LC.
A repost but a necessary add-on to this thread.
From NGK: 5 Things You Should Know About Spark Plugs
NGK spark plugs feature trivalent plating. This silver or chrome-colored finish on the threads is designed to provide corrosion resistance against moisture and chemicals. The coating also acts as a release agent during spark plug removal. NGK spark plugs are installed at the factory dry, without lubrication or anti-seize.
Anti-seize can act as a lubricant, altering torque values up to 20 percent, increasing the risk of spark plug thread breakage and/or metal shell stretch. Thread breakage can sometimes involve removing the cylinder head for repair. Metal shell stretch changes the heat rating of the spark plug and can result in serious engine damage caused by pre-ignition. Do not use anti-seize or lubricant on NGK spark plugs. It is completely unnecessary and can be detrimental.
So I’ve read most of this thread and now know WAAAY more about plugs than I ever thought I needed to, but still a little confused.
1. Dry or wet? There seems to be consensus between this thread and manufacturer guidance, that applying anti-seize can lead to problems. But the galling that I observed with the NGK plugs in my engine suggests that a little lubrication will help avoid mechanical damage to the aluminum block threads. I used a drop of engine oil.
2. Torque? FSM says 13 ft/lb, mine survived 60+ ft/lb (too much obvs) and 18 ft/lb seems to be ok? However, even 25 ft/lb can be undone with a flick of the wrist, so does it really solve the problem identified at the top of this thread?
If the plugs were easier to access, it would be no big deal to re-torque at every oil change, but it’s easily an hour once you remove and replace all the stuff blocking the driver side coil packs.
Lubing threads!! o_O
Very risking, even torquing to spec of 13ft-lbf. If threads lubed in any way. I've seen test on youtube. Of thread lubed, before torquing. They can be as much as 100% (double) over torque. So at 18ft-lbf lubed thread (anti seize or oil) you may be at 36ft-lbf.
Could your galling be a consequence of your insanely overtorqued plugs?
Retorquing plugs every oil change seems like overcomplicating this particular issue. If you are concerned about thread health, run a thread cleaner before installing new plugs dry. Make sure your torque wrench is roughly calibrated, torque to 18 ft/lb, then change after 60k.
I listen to my truck for the tell-tale signs of these plugs walking out. If I heard even a hint of the tick tick tick I would plan to do plugs.
When I removed these plugs for inspection, I used my torque wrench to REMOVE after I struggled with the first one. Wrench was set at 30 ft/lb and it clicked and required much more effort after the click. I’m estimating 50-60 ft/lb to break the grip and continuous 15-20 ft/lb to fully remove.
Plugs are correct and look ok but plan is to replace with new and start fresh, with a dry install. My question is about the head threads, which maybe have been stressed:
1) how do you correctly chase them and avoid debris in the cylinder? I’ve read about making sure the piston is below TDC, greasing the chasing tap so debris sticks to it, blow gun, vacuum, borescope, etc. is it really that complicated?
2) what to look for to assess thread health? If the new plugs are going in smooth and dry, is that enough?
You use a thread back tap, like this one.
It's able to be inserted into the hole, then you expand the threads and run it back out slowly. It cleans the threads and brings any debris with.
I have used one for soot caked glow plug threads on VW TDIs.
