OK - so its a few years late - but I just snugged up the RH bank to 17 ft.lbs too - all plugs still tight (#3 maybe moved 1/32 of a turn) - am happier with 17ftlbs torque (up from 15ftlbs original torque....)after 3k miles - checked LH bank of cylinders - 2/4/6/8 - all plugs tight - however set torque wrench to 17ftibs and snugged them up slightly, from previous 15 ftlbs. Will do same with RH bank in due course.
Sorry to hear.I am extremely ticked off. Just completed a 3000 mile trip from Nashville,TN to Moab UT and back in our 2001 lx470. Spark plug blew out of the passenger side head today. Plugs and all coils were replaced 70,000 miles ago. I did not hear any ticking on cold start up and during our trip at every gas stop I would listen for a pop or ticking. Only once while idling on an easy trail did I hear a ticking and it went away and wasn’t heard again. The truck has 340,000 miles on it. I’ve always bragged on Toyota and I own 7 land cruisers from a 1966 up to this 2001 lx. But this is completely ridiculous. I was even considering putting a 2uz in my fj40 because of the reputation of the million mile motor. I’m so ticked I have kept up with maintenance and oil changes etc. Not sure what I’m going to do… replace the head or put in the diesel 1hd-fte I’ve always wanted or just get a completely different vehicle or maybe even switch brands. I’m just so disappointed. Truck is completely built and has been so reliable. I’m just thankful it didn’t happen in the middle of nowhere at night.
JasonView attachment 4083132
Any used none VVt 4.7L 2UZ head, will work. Just do your home on engine. "Low, good oil change history, good air filter, no vacuum leaks. Have head inspected and tested.@2001LC Denso bought from McGeorge/ourismon Toyota. Any recommendations on where to get a head? Haven’t done a research on head availability yet. Thanks for any help
Jason
This...IME the 2UZ is one of the best engines ever made. A torque spec that's too low is a pretty easy issue to resolve. I don't understand the mentality at all, but I do understand the frustration. You can install a time-sert and be back up and running quickly with zero negative impact on the vehicle or engine. Then start tightening the spark plugs to 18 ft.lbs. Problem solved.
