For reference when I replaced my plugs a coil a year and a half ago I torqued to 13 ft lbs and a few weeks ago I checked them and all but one or 2 were a small bit loose. Needless to say I torqued them more...
Ok, I have been searching every variation, with the coil part number and any other keywords I can think of....but you have a part number for this "boot and seal" kit?I like to blow off loose sand & dust, even washes engine or before beginning. You must take care not to get any dust into heads. I also use an air pistol, to blow out spark plug tube, before removing plug.
Here a few pictures that may be helpful.
Air box removed reveals RH plugs #'s 8, 6, 4 & 2 (#2 front of engine).
Plugs #1, 3, 5, & 7 (#7 rear by fire wall) are accessible once fuel bracket removed.
Two 10mm bolts secure the fuel bracket that's in the way.
To remove coil pinch at top to release catch and pull off. I use a needle nose pliers to pinch and pry off with a wide blade screwdriver between bottom of wiring housing block & coil or a hook like screw driver to pull off. This must be done very very very gently or you will break the tab of clip or wire housing. Just take your time and go easy, they can get stuck from dirt jammed in it.
Once coil out. Use compressed air, to blow dust out spark plug tube.
Here is and example of coil boot premature aging from heat. Notice the two brown boots compared with the one good gray one.
The brown boot indicates prematurely aged. Can be seen cracking when squeezed and are no longer soft and pliable. Denso sell a boot& seal kit. Which I use with spark plug changes. Number one concern, even if they look good. Is the top seal. It keeps dust out, and water from washing in sand/dust.
Denso 671-8184Ok, I have been searching every variation, with the coil part number and any other keywords I can think of....but you have a part number for this "boot and seal" kit?
See this is what makes a good mod a great mod. Thanks @Trapper50cal. I actually bookmark many of @2001LC threads because they’re so thorough, and I had a vague memory of there being a cautionary tale around plugs, but I couldn’t remember. Thanks for pointing me the right way.ttt for @Super77
Not a mod but thanks for the compliment just the same. I just remember having to use a breaker bar to get my plugs out and sweating bullets that I wouldn't bugger up the threads in the head...scary stuff. Don't want that befalling anyone else if it can be avoided.See this is what makes a good mod a great mod. Thanks @Trapper50cal. I actually bookmark many of @2001LC threads because they’re so thorough, and I had a vague memory of there being a cautionary tale around plugs, but I couldn’t remember. Thanks for pointing me the right way.
I had one took 3 tank full of gas w/44K and 3/4" breaker bar. I too was sweating bullets. It wasn't the time I'd seen where anti seize was used on threads (bad idea). They walkout, and as the hot combustion gasses cooks anti seize, hardening and caking in threads.Not a mod but thanks for the compliment just the same. I just remember having to use a breaker bar to get my plugs out and sweating bullets that I wouldn't bugger up the threads in the head...scary stuff. Don't want that befalling anyone else if it can be avoided.
lol you’re everywhere here so just assumedNot a mod but thanks for the compliment just the same. I just remember having to use a breaker bar to get my plugs out and sweating bullets that I wouldn't bugger up the threads in the head...scary stuff. Don't want that befalling anyone else if it can be avoided.
I re-removed the ones I torqued to 13, wiped off the anti-seize, and put just a drop of motor oil on the threads instead. When fully dry, they really gall. Maybe new ones don’t, but I figure a drop of oil won’t cook like anti seize on mine, which have about 45k on them and look serviceable.I had one took 3 tank full of gas w/44K and 3/4" breaker bar. I too was sweating bullets. It wasn't the time I'd seen where anti seize was used on threads (bad idea). They walkout, and as the hot combustion gasses cooks anti seize, hardening and caking in threads.
NGK spark plugs feature trivalent plating. This silver or chrome-colored finish on the threads is designed to provide corrosion resistance against moisture and chemicals. The coating also acts as a release agent during spark plug removal. NGK spark plugs are installed at the factory dry, without lubrication or anti-seize.
Anti-seize can act as a lubricant, altering torque values up to 20 percent, increasing the risk of spark plug thread breakage and/or metal shell stretch. Thread breakage can sometimes involve removing the cylinder head for repair. Metal shell stretch changes the heat rating of the spark plug and can result in serious engine damage caused by pre-ignition. Do not use anti-seize or lubricant on NGK spark plugs. It is completely unnecessary and can be detrimental.
When I removed these plugs for inspection, I used my torque wrench to REMOVE after I struggled with the first one. Wrench was set at 30 ft/lb and it clicked and required much more effort after the click. I’m estimating 50-60 ft/lb to break the grip and continuous 15-20 ft/lb to fully remove.Lubing threads!!
Very risking, even torquing to spec of 13ft-lbf. If threads lubed in any way. I've seen test on youtube. Of thread lubed, before torquing. They can be as much as 100% (double) over torque. So at 18ft-lbf lubed thread (anti seize or oil) you may be at 36ft-lbf.
You use a thread back tap, like this one.When I removed these plugs for inspection, I used my torque wrench to REMOVE after I struggled with the first one. Wrench was set at 30 ft/lb and it clicked and required much more effort after the click. I’m estimating 50-60 ft/lb to break the grip and continuous 15-20 ft/lb to fully remove.
Plugs are correct and look ok but plan is to replace with new and start fresh, with a dry install. My question is about the head threads, which maybe have been stressed:
1) how do you correctly chase them and avoid debris in the cylinder? I’ve read about making sure the piston is below TDC, greasing the chasing tap so debris sticks to it, blow gun, vacuum, borescope, etc. is it really that complicated?
2) what to look for to assess thread health? If the new plugs are going in smooth and dry, is that enough?
