- Thread starter
- #481
I'd not use anti-seize:
Anti-seize (thread lube) will cook and harden in threads, creating extra carbon build-up in threads. This happens, as the spark plugs begin to walk-out and the hot combustion gasses mixed with and heat thread lube. Which will stop walk-out, locking threads in, like a permanent high temp threadlocker. But this can cause spark plugs, to seize in the head. So don't leave in for to "many" heating and cooling cycles, if using A-S. How many H&C cycles is to "many", who knows. But I can say the walking-out is not about miles, it's about heating and cooling cycles (H&C).
I've had occasions. Where I've had to use a 3/4" breaker bar to get spark plugs out, when anti-seize used.
That was after months of adding 44K to gas tank repeatedly and penetrating oil into spark plug tube. First tried 3/8" breaker bar, than 1/2" and finally had to get out the big-boy 3/4" breaker bar. Talk about risky! It was a "hail-mary-pass" last effort. Not just the breaking loose, but almost every turn of getting all the way out was very difficult. Only the last few turns didn't take extreme force. I was shocked, I didn't bust the spark plug in the head or damage the threads. Not something I'd like to even attempt again.
Everyone needs to consider this:
This alert is about spark plugs walking out (loosening) on their own. So why would we even, consider use of anti-seize as even remotely needed
