Throttle Cable Part Number Clarification
Southeastern Virginia
Greetings. 1995 FZJ80.
I’d like to replace the throttle cable on my 80. It’s nearly 30 years old and the plastic sheathing is starting to deteriorate.
I’ve done some searching on Mud & PartSouq and have found that part 35520-60140, the throttle cable associated with my VIN, is NLA (including on PartSouq).
PartSouq lists part 35520-60111 as a possible alternative, but the parts manager at my dealership (who can order that part from Toyota) believes that cable will be too short.
Question 1 - has anyone successfully installed 35520-60111 in a later model (95-97) FZJ80?
Also, would like to replace the cruise control cable with the same issue, but part number 83731-60020 is also NLA with no alternatives that I could find.
Question 2 - any updated part number or legitimate overseas sources for a cruise control cable for a 1995 FZJ80?
I know eBay has several options, but I’m not at the point where I’m willing to trust those sources (may have to eventually I guess).
Many thanks…and my apologies in advance if I missed an easily identified option or search result.
Edit: The following response is not relevant to the OPs question. Thanks for helping me understand @OGBeno.
Mine is a '94, but it is also a 1FZ and uses the same cable. I used part number 78180-60280. I bought it from Japan because it was a lot cheaper and I wasn't in any rush.
It shows up as available on Olathe parts site. It would say discontinued if NLA.
I removed my cruise control, so can't help there.
Thanks much. Certainly appreciated.
That’s the accelerator cable. He’s talking about the throttle cable which is commonly referred to as the transmission kick down cable.
Thank you. I misunderstood.
I'm looking at the same issue right now. You ever get an answer on this?
And is there any meaningful difference between 35520-60111 and 35520-60140? Because when I order the 60140 on a dealer website, it tells me it's a perfect fit and lets me order--but when I actually look at what I'm ordering, the P/N has changed to 60111. Which would really suck if it's not a proper fit...
@OGBeno?
Apologies for the late reply @jaymar - see you started a separate thread for your throttle kickdown cable quest.
I was using incorrect terminology originally. I needed to replace the accelerator cable on my 95 80. Never did find a new throttle kickdown or cruise control cable.
The accelerator cable was all that had deteriorated on my vehicle. Easy to swap.
Good luck!
