Does anyone know what is the thread size on the oil pressure sending unit? This is the round looking thing on the passenger side of the block, under the Oil cooler. I think it's 1/8" BSP but definitely NOT 1/8" NPT. I base this assumption on this: I can screw the sending unit inside a 1/8" NPT hole. But, I can't screw in a 1/8" NPT nipple inside the hole in the block. There is a taper inside the block that prevents a NPT nipple from engaging more than a thread or two.
I'm basically planning on adding a Brass T so that another mechanical gauge can share the same pickup point on the block for measuring oil press.
Thanks.
Thanks.
