The Wall of Shame (1 Viewer)
That's disgusting, they could have ,at least, put a nice radius on the corners, maybe some decorative scrolling and a nice pecan stain:)
That's what the :hillbilly: emoticon is for!
That emoticon means you're a fan of Divine.
:rimshot:
Talk about a wall o' shame ....
My eyes, my eyes!:eek:
For today's contribution I give you a corkscrewed carburetor slo-jet. This happens when you ignore or forget the placement of the jets in your early '70s Aisan carb in an effort to get a larger jet than stock into the shallow primary bore. There's a reason they made the hole shallower: SO YOU WOULDN'T DO THIS!!!
That deserves a, WOW!
The best (of worst I've seen) was a SBC that had two small triangles of 1/4" steel bolted to the front of a SBC to connect it to the frame. If one of the 5/16" grade 5 bolts broke the engine would fall out.
Don't do it... at least use a saddle mount.
The owner of my local muffler shop told me he had a guy come in who had tried to replace his rusty exhaust system with white PVC drain pipe.
Does he have a wall of shame?
I will see if i can dig up that spacer Mark. Its been awhile since i pulled it off like 12 years haha
Natural products, like tar impregnated paper, asbestos and leather were used as gaskets and seals up until the 1950s. Although the plastic, Bakelite, was invented in 1907, it was too expensive and was used for more valuable applications like jewelry and appliances.
My grand dad told a story of fixing either a model T or A rod bearing with shoe leather. I'm not sure of its longevity, but it seems like it was commonly done as a field repair.
The original bearings were poured Babbitt and when they went out they were often replaced with leather. Replaceable Babbitt bearings came in in the late 20s I think and were common after the 50s. The funny thing is how much jewelry was made from Bakelite in the 1920s. It was new and cool.
Not sure the consequence of this little jem, but this 2F will never ride again. Must have just grabbed parts that were the right length? not sure.
Fan belts were leather back then.
Bakelite is a trademark for a thermoset phenolic resin composite. The phenolic composites still have many uses.
When they were still making aluminum on a limited production basis its price per ounce was higher than gold.
