Builds The start of a never ending build, new 80 owner
UPDATE: alright so lights started showing up from PTLX Global, an industrial lighting company that seriously puts rigid, kc, vision x and many others to shame.. If you want the best of the best, get a real industrial light and not a automotive light from a "industrial company." Anyway! I need a place to put these lights so with the help of das mule, busted out a light bracket to add to the new bumper! Blah blah blah wired some lights and here ya go!
Aesthetically, that's exactly what that bumper needed too. Looks perfect!
They are incredible haha, so much hate saying I'm blocking the radiator so it will overheat yet my truck seems to hold 186 degrees still.. I see no issue
I used to get the same comments in my previous setups when I had even more lights covering the whole front end. Never had an issue running hot. The way I look at it, when you're driving along at normal speeds the air is getting forced in no matter what. Putting a few lights in front of the grill isn't going to block the airflow. Stopped at a light you're not getting air forced through the grill, only what the fan can pull in. And in this scenario with the fan doing the work, the lights are a non issue again unless they create a tight seal around the grill opening.
My thoughts exactly
Exactly my thoughts, it finishes it off perfectly and I may have to recant my posts about square LED's I've made in other threads!
Still blown away by your work/truck. I'm copying everything! Even considered opening a Canadian version of your business. I'm calling it "The Jackass". Anyway, phenomenal truck man!
Thank you! Mule is not my business just a local shop I am friends with and let me use once and awhile!
