FJBen
What’s the wonderbread trick with a throwout bearing?Looks like it's time for the Wonder bread trick.
I’m not sure but it’ll make you wonderWhat’s the wonderbread trick with a throwout bearing?
My bad.What’s the wonderbread trick with a throwout bearing?
This video shows the same issue and apparently its the clutch throw-out bearing...
Yep, brand new throughout and pilot bearing. Maybe it could have washed it all out who knows@theglobb
Sounds just like a throwout bearing. Did you put a new one in when swapped clutch disk? I’m wondering when all that oil went in it if it washed the grease out.
This is exactly what I’m gonna do. No not pull the transmission out, just roll with it. Anyone know if a throughout bearing can fail catastrophically? This is one of the few things I’m thinking I’ll just drive with until it literally explodes on me, or you know if it’s making a horrible sound or affecting the way the car preforms.I was having a similar issue with my truck recently. We pulled the trans to change the clutch and hopefully address the noise. We found what seemed to be a failed pilot bearing but no evidence that there was an issue with the throwout. After changing and reassembling, the noise went a way for a few weeks then came back. For now I'm just rolling with it...
There's plenty of people more knowledgeable than me on here but I think the whole assembly would have to explode for it to be a problemYup, throw out bearing is what I was thinking. It’s really the only moving part other than the pressue plate when I manipulate the clutch pedal. Video seems spot on, thanks
Your clutch disc will shake around really bad causing your truck to shudder whenever you let out the clutch when the throwout bearing is really bad. If you however learn to move your feet properly you can negate 75+% of the slop in the bearing on letout. As the RPM's come up the clutch disc will center itself Since it only makes the noise in neutral my guess is it's minor slop on the bearing and because there is no "force" holding back the tranny it is not forcing the clutch disc to center and bearing slop to go away, or perhaps it's input bearing slop combined with throwout slop................If it is in fact your throwout bearing, and all you got is that little noise I'd say you have a long way to go before you need to worry about anything flying apart. Other's please chime in here. .........Really perhaps you just need to load it up with attractive passengers and test.Yup, throw out bearing is what I was thinking. It’s really the only moving part other than the pressue plate when I manipulate the clutch pedal. Video seems spot on, thanks
Are you going to run rope or cable? For rope with the ARB you are going to want to get an offset hawse, otherwise the rope is going to rub on the bumper. Mine is a simple Aries brand made of aluminum. You can go fancier and get something like a Factor 55 but this works well enough for $60. If you are going to run cable, then the bumper has a built in spot to run the rollers on that lip that sticks out.
For the bolts it should through bolt using the 4 (well 3 in the photo) that you can see on my bumper. There should be nuts that are inside of the legs of the winch. You might need longer bolts than were supplied with the winch.
You can clock the lever to have it be on the top and make it more accessible. There are a few videos on the instructions for that on YouTube, its pretty easy. Basically just unbolt the side with the lever and cover, dont remove it and just rotate the lever and cover and then bolt it back up.
Girl our age with a 40? Hey, give her my number.Nothing crazy just went on the hunt for some dead trees to use as fire wood for this coming winter. My house is only heated by wood.
The beginning of the haul of wood. should have taken an end result.
Also pretty cool thing happened last night. Was going to watch the sunset on the Blue Ridge Parkway when I drove by a rotten 40 parked at an overlook. Turned around and went to introduce myself, turned out to be a girl my age who goes to my college who bought it back in January. SUPER ROTTEN. 1970 with original drivetrain and all. She is pretty clueless when it comes to cars, said she just learned how to change her spark plugs and change the oil. Obviously, I offered my help and knowledge whenever she would need it and said I'd show her how to change the diff and tranny fluid, ontop of having access to my driveway and all my tools. Her knowledge level is around where mine was when I was 17 with a FJ62. Who would have guessed 2 years later I would learn how to DIY turbo my 3B, 3 years later my engine would have blown and 4 years later here I am with my completed engine swap driving around Appalachia. Hope to help her get started.
View attachment 3429789View attachment 3429786View attachment 3429785
