**HAPPILY RETIRED**
Rotors 42431-60290
Pads 04466-60160
If you have any corrosion you may want a shim set 04946-60120 and slide surface kit 04948-60040
Even though my understanding was the rear brakes for all 200-series cruisers were mechanically interchangeable, I don't see 60161 until 2019+.. and even then there is a note for "Mark Advics VC107" while keeping 60160 listed for Mark Advics VC044.Pads are 04466-60161
That is a reference to another parts diagram, in this case the one for body > spoiler & side mud guardWhere do I find fig 76 - 52 to find this PN? Kind of seems like it should be 90166-60003 like is used in the rear.
I spent a bit of time digging and can't find them so far. Reminding me of some other harness retainers that I know I've seen in diagrams over the years, but I can't find them for the 200. So I'll be checking some more mainstream toyota diagrams soon.Anyone know the part number for these zip ties. There are about 6-8 of them along the top of the firewall holding the wire harness to the firewall. They slide over the studs that are welded to body. There may be a few on the engine as well.
I remember a few months ago finding some diagrams with different zip tie contraptions, and that you could order them in differ3nt lengths. I’d rather have the Toyota ones, but there does appear to be reasonable facsimiles on Amazon. Just wonder how many heat cycles they last.I spent a bit of time digging and can't find them so far. Reminding me of some other harness retainers that I know I've seen in diagrams over the years, but I can't find them for the 200. So I'll be checking some more mainstream toyota diagrams soon.
Thanks. That looks pretty close. I found a picture of one on a FJ Forum. Looks like it has a part number on it. I don't have one in hand now but i'll investigate. I've got a few cut ones.The only part I’ve found so far for that tie is 82711-34450. While the 200 is not listed under apps, it is for a 6mm stud/post mount with wire bundle up to 30mm in diameter.
LH 81070-60N50Headlight assemblies (L and R) for a ‘21 HE. TIA.
Rotors 42431-60290
Pads 04466-60160
