The official part number request thread
Part number for rear rotors and pads on an '18 Land Cruiser?
Rotors 42431-60290
Pads 04466-60160
If you have any corrosion you may want a shim set 04946-60120 and slide surface kit 04948-60040
Pads are 04466-60161
Even though my understanding was the rear brakes for all 200-series cruisers were mechanically interchangeable, I don't see 60161 until 2019+.. and even then there is a note for "Mark Advics VC107" while keeping 60160 listed for Mark Advics VC044.
What is the difference between those two?
Where do I find fig 76 - 52 to find this PN? Kind of seems like it should be 90166-60003 like is used in the rear.
That is a reference to another parts diagram, in this case the one for body > spoiler & side mud guard
But yes your part number is correct.
Anyone know the part number for these zip ties. There are about 6-8 of them along the top of the firewall holding the wire harness to the firewall. They slide over the studs that are welded to body. There may be a few on the engine as well.
I spent a bit of time digging and can't find them so far. Reminding me of some other harness retainers that I know I've seen in diagrams over the years, but I can't find them for the 200. So I'll be checking some more mainstream toyota diagrams soon.
I remember a few months ago finding some diagrams with different zip tie contraptions, and that you could order them in differ3nt lengths. I’d rather have the Toyota ones, but there does appear to be reasonable facsimiles on Amazon. Just wonder how many heat cycles they last.
The only part I’ve found so far for that tie is 82711-34450. While the 200 is not listed under apps, it is for a 6mm stud/post mount with wire bundle up to 30mm in diameter.
Thanks. That looks pretty close. I found a picture of one on a FJ Forum. Looks like it has a part number on it. I don't have one in hand now but i'll investigate. I've got a few cut ones.
screenshot_20230502-212425-2-png.1229964
Just checked one of the ones off my truck. Definitely that part. Partsouq didn’t have them. Almost $5 a piece from NA dealers. Not sure I want a handful of them that bad.
If I had known they were that expensive I would have saved more of them rather than cutting them off.
I’m having trouble locating the p/n for this torx head screw that goes between the rear bumper cover and horizontal plastic behind the rear mudflap.
‘21 Base LC
Headlight assemblies (L and R) for a ‘21 HE. TIA.
LH 81070-60N50
RH 81140-60N50
Just a caveat.. for expensive stuff like this I'd verify the numbers with whoever you are ordering from. That way if I somehow fat-fingered the numbers you aren't on the hook for the cost.
Looking for the part numbers for front OEM brake pads and rotors for 2013 AND 2016.
Rotors 42431-60290
Pads 04466-60160
Are these part numbers good for all years?
