The official part number request thread
I went to look at this diagram and dont believe what he is looking for is in the picture.
Pretty sure it’s on this page, but good luck picking it out.
Oh. Thanks for that diagram. It might be Toyota 53271-60020 Bracket, Headlamp Mounting, RH
upper left’ish in the diagram
If you do a google image search for that part number there are some promising results.
Also note that @lx200inAR diagram appears to be for an LX, and some of these will have different parts than LC.
Thanks @bloc and @lx200inAR for looking. Better than googling for “you know that part that the other part connects to”
Update: I’m pretty sure it’s these two parts.
Does anyone know the part number for the 9th body mount bolt (2013 LX570, in my case)?
EDIT: I found it:
5717960030​
Come on guys, help me out. I am considering a replacement steering wheel for my 2020HE. It is not flaking but has a couple nicks by PO's wife jewelry. Since it is a HE, I have the bronze stitching and could not find a reliable source to confirm the actual PN replacement for the HE with bronze stitching (as opposed to gray). I know from the steering wheel replacement thread that there is a PN for the steering wheel, but I think that one is for the full leather replacement (without the wood section) and with gray stitching. I have tried reaching out to some parts depts, but none could help me with certainty. You guys are my last resort. TIA
Call your dealer with your VIN handy. There are at least 5 possible part numbers.
The factory catalog should filter the part number based on the VIN.
I’m looking for the wood trim on the upper part of the drivers door. I can find the number for the whole door panel but not just the trim. Mine has lifted just above the seat memory buttons.
2013 LX with black interior.
Thanks
View attachment 3719946View attachment 3719947
did you ever get this part number? Mine has cracked and lifted in the same spot.
As far as I have always understood, these were not available without the whole door panel. But a user did somehow find a set, or actually i think he had multiple sets. Not sure if he had them made or what. Pretty sure that user sold his LX, so not sure if he still hangs around.
The lighted drivers side floor sill at the door on my ‘17 is flickering. I confirmed the sill channel and connectors are clean and dry. The problem is water from my boots seeping into the top of the lighted portion of the sill and corroding the lights. The info on the removed sill reads Assy 770 with 2 part numbers: 67920-60011 and 67914-60171. I can’t tell from the parts diagram I use if one of those is just the lights. I really need the entire sill with the lights as an assembly to get a good seal.
It’s the -60011 number, and it probably ends with -C0.. if so that’s the color code for black.
Punch the whole thing in to a parts site and it should show up.
Thanks. Just what I needed to know. But…….at $300 I’m happy to just tape off the connectors, reinstall the one I have, and do without the lighted Land Cruiser signage. :confused:
Trying to replace the windshield wipers with factory oem blades/inserts for my 2013 LX. Front (2) and rear (1)
It currently has Bosch wipers on it which I'm assuming means I need the OEM replacement blades + the inserts. Can someone provide what the part numbers are and if Toyota ones work or do I need Lexus?
Also, for the rear, if someone has a pic of what OEM vs. aftermarket looks like that would be great. I'm not sure whether or not I need the blade or just the insert. Thanks!
Left blade: 85222-42110
Right blade: 85222-53071
Both come with inserts, though they are available separately to get clean glass if the blades are still in good shape. I usually keep a couple sets on the shelf. My blades tend to last about 4 years before the sun exposure degrades the plastic to the point of being visible.
Left refill/insert: 85214-06140
Right refill/insert: 85214-53080
Rear refill/insert: 85214-42040
I’ll try to get a pic of the rear in the morning.
Factory rear wiper
