The official part number request thread (21 Viewers)
@bloc can you tell me the type of bolt needed for where the 3rd row seats bolt to the floor?
Also, is 16400-50384 the correct # for the replacement OE radiator?
Thanks!
I think the bolts are 72702-60070 but the diagrams are pretty tough to tell for sure. Seems right on the pictures.
Yes that's the correct number for the rad. Should be the updated part.
This is awesome, and could you list the rest of them? Thanks a bunch
09120-60210 Tool case
09150-60030 Lug wrench
09116-35080 L-shaped turning handle end
09115-35110 Jack adapter end
09114-60070 Extension rod 1
09114-60080 Extension rod 2
09114-60090 Extension rod 3 (the part with the T)
99913-11500 Pliers
99915-10700 Screwdriver
99914-10810 8x10 wrench
99914-11214 12x14 wrench
09155-74010 Spark plug wrench
09183-00030 Hub cap pry tool
09111-60120 Jack
I'm looking for the Vacuum Switching Valve Assembly which used to be part 25860-0S020. I have a 2021. I am hoping to confirm/clarify which new part I would need for the assembly that sits on top of the engine. I think it's 25860-25040, but wanted to confirm. TIA!
Please attach a picture of what you’re after. I show the original 0S020 number still being available at my usual parts site, so no reason to run a different part, unless I’m misunderstanding what you need to do.
But as I remember it there are a couple VSVs up there so a picture can help me hone in on the correct number.
The 0s020 is what I have written down for what I'm looking for! It's not showing as available on Fred Anderson's website for some reason. I will try again on another parts store option, but think this is what I'm seeking. To confirm: it should be 25860-0s020?
Thank you!
Thank you!
The reason I asked for a picture is there are indeed two VSVs on top of the engine. Per the original parts diagrams they are 25860-31060 and 25860-38010
The first number is superseded by 25860-0S020 at the site I use, and it does show available there. Parts.autonationtoyotasouthaustin.com for the record.
You could try the original number at your site and see what happens.
charcoal/EVAP cannister for a 2021 please.
@bloc can you help me out with the number for this center console assembly? Is it all under one part number? If the shifter assembly is separate, that would be ideal info. Thanks much!
I really need a model year and even better build date for this one.
The model year applies to all requests actually.. really cuts down on the back and forth.
MY2015. I don’t have the build date offhand.
Looks like 58804-60A30-C1 for black interior. Note that the switches and their panel, the little panel under the hand brake and hand brake boot are separate parts.
The shift pattern surround is 35970-60110 and you probably won't like the price. This doesn't come with the "lens" under it that illuminates things, nor the sliding cover that moves with the shifter to hide the gaps under the pattern slot.
You’re a legend. Thank you.
The T30 torx head bit for my mud flap. TIA!
Brake controller harness (the one in the glove box when you buy the vehicle). I had one, I put it somewhere so safe, now I can't find it. :bang:
I don't see anything obvious in the EPCs. I'm thinking it may be a port included part.. Might be worth reaching out to the community, or maybe a really good dealer parts guy.
Yeah, I couldn't find it either, although I believe you have better tools than I do. I talked to Redarc this evening and they have a controller kit with the complete harness, so I guess I'll just go that way. Thanks for trying.
Ordered the alternator brushes kit today (along with a LOT of other stuff), thanks again for that nifty thread.
