A piece of metal hit my front bumper on my '13 LC. Any idea what part this is? I believe it's part of the washer system that cleans the headlight.
VIN: JTMHY7AJ7D4013516
That is your headlamp washer port. There is usually a cover that is painted the body color on top of the nozzle.. thing is the nozzle assembly isn't visible and that makes me wonder if the mounting brackets for it broke and the thing fell down inside the bumper.A piece of metal hit my front bumper on my '13 LC. Any idea what part this is? I believe it's part of the washer system that cleans the headlight.
VIN: JTMHY7AJ7D4013516View attachment 3969258
Wow @bloc! Thanks so much for explanation and help!!That is your headlamp washer port. There is usually a cover that is painted the body color on top of the nozzle.. thing is the nozzle assembly isn't visible and that makes me wonder if the mounting brackets for it broke and the thing fell down inside the bumper.
You can go to the one on the other side and pull up on it to get an idea of how it works.. when you go to clean the lamps the fluid pressure forces the washer the nozzles upward then when you're done a spring pulls them back down to bumper level. You won't hurt it by pulling up a few inches.. it'll have a clear point that it stops moving.
That said, if the nozzle is ok and you just need the cap that is 85354-60050-B0 for a silver lefthand side. If you need the whole washer nozzle it is 85208-60060 for left hand.
You can get access to the nozzle by opening the fender lining skirt where it attaches to the bumper skin in front of the tire.. a few T30 torx screws on the side and a couple 10mm on the bottom, and the liner will move enough to get a hand in there. I know from experience the 10mm bolt that attaches the nozzle to the bracket is quite difficult to get to.. but it can be done with the bumper in place.
82169-60080 Should include the damaged bracket and plug right in.A request please. The harness for the tow hitch, for power/lights/whatnot. Clearly caught this somewhere and its about time to address it. I assume its plug and play?
94151-21601Request please. Front passenger side nut for KDSS for 2008 Land Cruiser. Just need the nut. Thanks!!
where'd you order from if you dont mind?Right. Also comes with the new bolts for bracket to the frame. Just installed one on mine.
Got it from Japan for $100 to my door.
Hi @bloc
Could you tell me the part number for the cover for the center console?
Or maybe it’s called the arm-rest for the center console.
The lid to the center console.
My dog has stood on mine too many times and the leather (fake leather?) is all scratched up.
I have a 2021 Heritage LC 200 with black leather interior.
This is without the center cooler in the console, if that makes a difference in the lid.
Thank you!
Requesting a part number for the HVAC trim piece for under the middle row seat, passenger side. Also the volume/tune knobs for the back side of the center console. Having trouble finding these on any diagrams. Truck is a 2008 LC.
I can't find the thread with it listed, so I'm sorry ahead of time @bloc ,etc
I'm looking for brake hardware for front/rear of a 2021 LC. Think caliper pin boots, caliper pins, etc to have some spares on hand. I'm not sure what the options are and want to be ready ahead of time and not scrambling. TIA.
Thanks again for this. I just put in an order for all sorts of brake stuff.2021 LC
Front
pad retaining pin (4) 90240-06024
(no boots for the pins on the front)
"fitting kit" includes a full set of anti-rattle and retaining springs 04947-60140
Separate, they are:
pin anti-rattle spring 47748-60280
pin retainer spring 47743-60280
Front caliper bolt 90105-14198 (I keep 2 spares of this in my roadtrip kit)
Rear
Caliper bracket bolts (4) 90119-14169
Caliper slide pin (4) 47715-43010
Upper slide pin boot (2) 47775-35010
Lower slide pin boot/bushing (2) 47769-35010
Full kit of 8 pad-wear surfaces 04948-60040
Wear indicator plate (2) 47771-22030
Beyond all of that you're talking piston seals and dust boots.
Looks like it only comes with the handle. Assuming yours is "Deep Blue MC" that would be 69210-60280-J0 for the handle, and 69250-60060-J0 for the driver's side lock surround.Looking for the part number for the chrome piece on the door handles on a 2018 LX570.
