This thread is about the fuels pump on 1Hz, 1HD-T, 1HD-FT and 1HD-FTE.
It's simple seen, TWO pumps VE6 ?? and VP6 ??.
I think is we should stick to these pumps.
Although Clearly I want to know what you think of other points. Especially engine - gear. However, it does not belong to this thread.
Nor a 1HD-FT D4D.
I build in 1HD-FT and 1HD-FTE WITHOUT E (VP)
There is small difference between the 1HD-FT and the 1HD-FTE. As a bit better cooling strategic places at the top. There are one or two other things that I do not remember right now.
Please.
Pm me or refer to other threads where the other issues can be discussed.
What I look for are:
A VE pump with electronic ignition control. (Not a modifyed VP)
Electrical rpm limitation.
Enough fuel for even the wildest build.
Regulereing of fuel compared to the boost pressure from idle to ???? RPM.
As, for the thread additional topic, it is clear that the injector nozzles are very important. Otherwise, such a pump will easily self-destruct.
At this stage there is no limitation as long as we are at VE6 ?? pump - possibly P pump (but not very interesting because I do not want such a pump. But it is an option.)
Parts - things to discuss, as a starting point:
Pump plunger. 14mm if it is in usable quality.
Cross cam plate. Immediate the part that looks weakest.
Cam plate. Available with different pump height. Up to 4 mm.
Fuel pin. Here, there may be possibilities for regulating a number of ways.
Internal pump pressure - fuel feed pressure.
My wish is:
Short injection discharge time (injection length).
Correct injection time. Possibly closed-loop.
Mechanical pump and the correct amount of fuel compared to the needs of given charged pressure.
With 14mm pump plunger one gets short injector length, for a given amount of fuel.
Cross cam plate/drive can probably be made in stronger steel than the original.
Cam plate can have up to 4 mm lift. With larger lifts, each injection providing more fuel. But shorter time to fill the pump plonger with fuel for the next injection. Here I will probably find one with less lift (something like 2.8mm) than standard (3.2mm as I recall)
Fuel pin must be adapted. But could be replaced by a stepper motor. Which requires too much electronics and is will be easier to use a VP pump (1HD-FTE) Which is just a stepper motor and associated control.
Internal pump pressure has no significance with electronic fuel injection time. And should be as low as possible but high enough to fill the pump plonger, with the given construction and maximum rpm. Therefore it would be appropriate with an external inner pump pressure regulation.
Finally, there is the temperature in the pump and filtration.
Optimal temperature for the fuel in the pump is approximately 60 degrees C as I recall. It helps when starting from cold and changing oil viscosity.
I think I remember the standard is 10my so a filtrereing better than it will only be an advantage.
I have not written this post to demean any of your post. No suggestion is silly, but can help to learn writer and others something.
I wrote this to try to get the answers I need to learn and think about my building and my desire.
Out of respect for the thread. I know too well long threads that takes hours to read through in order to try to find the specefike information I want.
Yes I know it's out of the box to remove the rpm controller in the pump and make it electronically. However, it is an attempt to get more flexibility and, if necessary relieve the drive from the pump to the engine.
If this inspire others to do something different, it is not wasted to discuss from these thoughts.
Please respect that this has taken hours for me to write because English is not my language.
If I wrote in Danish, I believe many of you will find it difficult to read and respond.
Pump plunger:
Cam plade and X drev:
Vane pumpe:
Pumpe drev:
