Update!
I've completely solved my s***ty driveability issues.
1. Put the guide pin against a stock profile.
2. Increased main fuel screw (now that it wasn't overfueling due to the "modified" pin side)
3. Put a 6mm lock washer on the threaded section of the pin, below the diaphragm. Essentially on the diaphragm seat, as Ian suggested. I adjusted for the extra material on the threaded section by putting a narrower nut on the top. This is to compensate for the fact the pin I have is slightly shorter than a "stock" 93 1hdt pin.
4. Turned down the "smoke screw" height adjustment lobe on the top of the compensator. Now that the rod is essentially thicker, I don't need the lobe maxed out.
Result: Quick and responsive off the line, no pre-boost lag at all. No black smoke. Good throttle response and power throughout the power band. Reasonable EGTS (pre-turbo, under 1250 on full throttle up long hills, no intercooler)
Still have my idle/grey smoke issue, but I am sure that's to do with my ancient injectors needing rebuilding (possibly pump too). Going to talk with Okanagan Fuel Injection about that this coming spring.
listening to a 1hdt at 6000 plus rpm is fxxxen scary!! Stopping it is even scarier!
