Another Late night . After i had everything tacked up ,Then the real fun starts Make sure everything will work
. I was fighting the coilover placement as i wanted more shock shaft showing at ride height . So i swapped out shock towers . Nope same issue.
. I then welded 2 inch plates to extend them . Still not great HMM . I then started looking at how to mount the ram
. i cycled the tires lock to lock and Houston we have a problem
.My tie rod hits the track bar mounts when the wheels get close to full lock
. So The wheels have to turn. that makes it clear i need to move the track bar back . Track bar moved Check. Wheels turn. Check . Track bar hits the upper link mount. Check
. I can fix that as it just kisses it . . I also remembered i had some shock mounts that mount to the side of the axle.
. This. would give me what i was looking for. . i can move the tower back about a inch also. to keep things in line. . I also think i will keep my saginaw box for this summer just because. its going to take a bit of time to get the full hydro set up. and i just do not have that right now . It will work great as is so . If i can get this thing back on her feet In the next week i will fell very confident . I need it driveable before May that way i have a month to finish up all the crap that takes forever to do like hook up my lockers and lights and stuff . I feel pretty good though The last 3 nights i really got alot done .
