So I upgraded the old and tired stock shocks to Bilstein 5125 all around. Now the front is way higher. How can I level the rig?
Probably the leaf springs are the issue .
Shocks don't typically change the height of the vehicle. Are you sure it wasn't already sitting like that?
Shocks won’t lift the suspension, gas or not, no difference. If the front end is higher, it’s because you may have get some movement to your (stucked) leafs. Drive around and you’ll be there than before.
The 5125's come in 2 different pressure ranges. Did you verify that you got 4 of the same ? If so the higher pressure one could cause the condition you have because the fronts are straight up and down where as the rears are tilted which would give the force of the shock much less power to lift hence the front is higher.
If you don't think the 5125's will raise the front some degree, buy some of the 270lb ones and cut the strap, 2 of those on the front of a 40 would have some effect.
Find out what went wrong before heading down an expensive rabbit hole.Would leaf springs that lift 2.25 Inches balance it out?
Look inside
Maybe you forgot to take your MIL out of the back after the weekend !
