Looking for the correct shocks for an SUA FJ40 (intended for up to 50mm lift over stock) but realized it’s not that easy to find the compressed and extended length numbers. I figure it’s ideal to determine the compressed and extended limits (eye to eye) of your vehicle's suspension as a primary consideration prior to selecting and matching to the specs for available shock options. The following data may be useful since it was not searchable within our forum. If you happen to have additional data, maybe for FOX shocks or other options not listed, please feel free to add (also please reply if there are corrections):
Koni 82 Series
2-inch lift
Front: 82-5020 (Heavy Track)
Dobinsons Heavy Duty
2-inch lift
Front: GS59-635 (Heavy Duty)
https://www.dobinsonsprings.com/index.php/component/edocman/?task=document.viewdoc&id=465&Itemid=
Bilstein B8 5125
2-inch lift
Front: 33-062518
Front: 33-185606
Old Man Emu
2-inch lift
Front: 60097 (Nitrocharger Sport) (Medium and Heavy Load)
Koni 82 Series
2-inch lift
- Compressed: 13.11 inches (333 mm)
- Extended: 19.88 inches (505 mm)
- Compressed: 13.93 inches (354 mm)
- Extended: 21.88 (556 mm)
2-inch lift
- Compressed: 12.12 inches (308 mm)
- Extended: 19.21 inches (488 mm)
- Compressed: 14.29 inches (363 mm)
- Extended: 23.26 inches (591 mm)
Bilstein B8 5125
2-inch lift
Front: 33-062518
- Compressed: 12.03 inches (305 mm)
- Extended: 18.50 inches (470 mm)
- Compressed: 14.06 inches (357 mm)
- Extended: 22.50 inches (571 mm)
Front: 33-185606
- Compressed: 15.91 inches (404 mm)
- Extended: 25.93 inches (658 mm)
Old Man Emu
2-inch lift
- Compressed: 12.4 inches (314 mm)
- Extended: 19.4 inches (493 mm)
- Compressed: 14.37 inches (364 mm)
- Extended: 23.50 inches (597 mm)
- Compressed: 14.17 inches (360 mm)
- Extended: 23.38 inches (593 mm)
