Is there a fitting that screws into this that will accept a zirk fitting?
Fantastic, thank you very much for your time. I am assuming that 3/8-19 is the correct thread pattern? You are much appreciated.Stick your grease gun in there and start squeezing. You could also drill the plug for a zerk fitting, that's the slick way to go.
If you want the ultimate in class, buy 3/8-19 zerk fittings and swap in.
3/8-19 BSP, R 3/8, 90 Degree British Grease Zerk Fitting 1 pc
ZerksPlus is a supplier of Hardened Steel, Stainless Steel, and Brass Grease Fittings. We carry a wide range of Couplers, Button Head, Adapters, Dust Caps, UNF, Drive in, and Flush Fittings in Inch, British and Metric Threads. The Terms Grease Nipples, Grease Fittings and Grease Zerks are...zerksplus.com
3/8-19 BSP, R 3/8, 45 Degree British Grease Zerk Nipple Fitting 1 pc | eBay
3/8-19BSP, R 3/8, 45 Degree British Thread Grease Zerk Nipple Fitting. Check: Surface Ball, OAL: 25.5, Shank: 7mm, Drive: 17 mm Hex.www.ebay.com
There needs to be room for the grease to expand when it gets warm.Fantastic, thank you very much for your time. I am assuming that 3/8-19 is the correct thread pattern? You are much appreciated.
Really!? A Japanese truck uses imperial thread?Fantastic, thank you very much for your time. I am assuming that 3/8-19 is the correct thread pattern? You are much appreciated.
Toyota uses a fair amount of strange and different threads from around the world, especially British.Really!? A Japanese truck uses imperial thread?
Is it not M10?
Really? I didn't find any yet except for the DOT enforced seatbelt bolts and the odd pipe thread.Toyota uses a fair amount of strange and different threads from around the world, especially British.
Toyota itself doesn’t use weird sizing. Japanese Industrial Standards (JIS) is what drives the standard for manufacturing. Once you learn the JIS standards you’ll see why Toyota and any other Japanese manufacturers have these threads.Really? I didn't find any yet except for the DOT enforced seatbelt bolts and the odd pipe thread.
Reason i ask is that 3/8 19 is about 9.5mm x 1.3. Very close to M10 x 1.25 (but not) and this is a very standard metric thread, so why would they choose imperial for this?
Sure, but this isn't a pipe is it?
The plug that is removed is a pipe plug so they use a pipe thread to seal. The plug is also large enough that you can do a visual inspection to see how much grease is in the knuckle.Sure, but this isn't a pipe is it?
