That lobster back might look pretty there, but flow is not going to be good. You've got a massive step at the entrance between the V band clamp ID and the pipe. Looks like 3" would have been a far better size.
That step up in size is going to cause extra turbulence and drag.
I've been wondering about that every time I see mention of a 4" dump pipe... is there any point if the turbo exit is only 2.5-3"?
@mudgudgeon - I remember you did it, from the photos it looked primarily in order to seperate the turbine and wastegate flows, but you also said something about creating an expansion chamber so there was no chance of backpressure on the turbine.
Is it just making the transition smoother than the V-band-to-pipe joint above that can reconcile your ideas with what @Dougal is saying?
While I've got you - your turbo is an -FTE CT20B with "a Supra 7MGTE front compressor housing to simplify connecting the intake."? Just the housing, still using FTE wheel? What is the difference in the housing?
(Sorry if I'm going over old ground again...)
