I like the video. Correct me if I'm wrong, but I believe you posted the link to the same video twice, not two different videos.
Are you worried about erosion on the compressor of the turbo. I've read in the past that the droplets hitting compressor blades can cause damage over time, This is why I believe they typically inject post compressor.
the compressor would certainly help with atomization though!
Good job! Whenever i struggle with bleeding for some reason, i just top off the reservoir, and let the gravity do the work. Opening only one bleed valve at a time, letting the fluid just push thru on its own. Can take an hour, but all you need to do is keep the res full. And drink beer.
