Yup. The sticker on the dash is for an aftermarket overdrive system it must have once had. The one on the heater is where the hub instructions go. The shifter directions are on the inside of the glove box door.
Thanks. Cutting off stuff on the front frame rails. Gotta cut off the axle side link brackets because I changed rod ends. got a good start on an AA style triple stick. Got the driver side vent mounted.
Looking good Todd! You should be done with yours before I'm done with mine! Where did you get the high pressure side hose for your Saginaw? I could use one!
"Omnes relinquite spes, o vos intrantes"
Something John should heed the next time he rides princess in your pig!
