@Widenbruck - you have the dash prewired & the FR locker connection on the firewall.
You either need swap floor harness or add the wires (swap make for 1
-tech job.
Esp since you have locker axle shells too.
The main floor harness, the intermediary harness that ties both RR corners, and the FR & RR axle pigtails are the 4 harnesses you need.
Other than that, just the ECU/relay box, rotary knob & pull the cluster to add the bulbs & holders.
It’s like playing with dirty/greasy Legos - lemon squeezey having a donor rig.
Remember the lockers only engage in L range w/o CDL switch & pin 7 mod - if you haven’t played w/ the lockers / locked rig much yet, don’t worry if nothing happens in H range.
Once you verify you did the basic swap right, then add in the CDL & clip pin-7 wire (black w/ blue trace).
—Keep variables to a minimum incrementally so you can backtrack/isolate stuff.
