- Thread starter
- #21
So do I not need access to the back of the hub then? I have access to a full shop and can definitely do the welding idea and impact gun.
x3 on a good day and it's still just nice to post here and get answers you can trust.If it broke flush with the drive flange, just remove the other drive flange nuts, washers and cones so you can remove the drive flange completely. This will give you access to about 3/8" of the remaining stud. You can then use penetrating oil to let it soak for a couple days and either use vice grips or weld a nut to the stud and back it out.Thanks guys. It broke about flush with the drive plate so I think I’ll have to center punch and slowly drill with lube.
