i use Lubeguard FIXX with good result
Cool thanks, just looked into it and it seems Lubegard, At-205 and blue devil are all basically Glycol Ethers. That being said its odd that only At-205 is struggling to put it out.i use Lubeguard FIXX with good result
I've read some of your posts about that, excuse my ignorance but which is which?I'll also add: AT-205 has been 80% effective on stopping input shaft seal leak. But only slows (if even that), output seal leaks.
Cool, I got a email back stating the same, nationwide backlog, he didn't elaborate though.
I'm tempted to give Blue Devil a try, it seems to have a lot of success stories but also some horrors of turning a small leak into a major one but who knows the situation in those cases. Their website does say it is also a placticizer which sounds promising. My leak isn't bad, doesn't actually drip but when I did my inners recently there was a small amount of fluid in both boot areas.
Correct output (boot cover) seal leak, are usually damaged seals. It may slow, but not often stop.So you are saying the AT-205 will not do much to slow down any seal leak that wets the boots.
It's a PITA but doable.I’m not sure if I’ve missed this through this thread but what is the easiest way to replace these hoses? Meaning how did you get access to the other ends? I have the hoses with me and new clamps but the space to get in there behind the air box is quite cramped.
I've seen them where someone poke holes in screen, presumably to get flow. But that is the first I've seen screen removed.Apparently there’s supposed to be a screen in there? Cleaned mine out today and found no screen to be had…
How would someone even do that!![]()
I wonder if it rusted out or something? My worst fear is the mesh is somewhere down the supply line clogging things up.I've seen them where someone poke holes in screen, presumably to get flow. But that is the first I've seen screen removed.
I've never pulled a the screen. But I do not think it's metal. So can't rust!I wonder if it rusted out or something? My worst fear is the mesh is somewhere down the supply line clogging things up.
I'm gonna throw an external filter on the return line, Magnefine makes a 3/8" barbed unit thats well reviewed.
Thanks for the info! I ordered some new spring clamps from McMasterson along with some low pressure hydraulic hoses from them to try as well. I'll report back on how that goesI use ultrasonic cleaner for reservoir w/Simple Green (currently), works well.
3/8 ATF cooler line works well for 98-02 return line (low pressure). But some of the 3/8" is thicker (larger OD) than others. If you get the thicker, than OEM clamps work well. But if the thinner (smaller OD) walled, they don't fit sung enough. For those I use fuel line clamps. The hose I was getting at Advance Auto, was the thicker.
For suction hose I always use OEM, with OEM clamps. There is 2 different suction hoses, depending on year. One being a hair shorter. But they both fit all years.
OEM clamps are all the same 98-07. Typically the old clamps are okay and reusable. Although, I have occasionally found some suction hose clamps bad.
