starting issue
CT
I replaced the fuel lines in the engine compartment and now starting my LJ77 takes a lot of cranking.
I tried the primer but it no longer seems to work.
The truck does start every time but I have to crank it for 15 to 30 seconds.
What could be the problem?
Thanks,
If the primer no longer works I would start there. Primers are a common failure on these 25-30 year old Cruisers, they start to leak air into the fuel lines, causing the system to lose prime. Another thing to try is to bleed air at the injectors once you’ve got the engine running.
Any hints on bleeding at the injectors?
I will give it a try.
I ordered the "CAP ASSY, FUEL FILTER" primer also.
Thanks
The rest of the story:
The primer arrived and was installed. Pumped up the fuel filter but there was some diesel leaking from the water level switch.
I ordered gaskets and a new switch, installed and pumped the primer again. No leaks this time.
Truck started right up, just like it used to. Sat overnight and started fine the next day.
Was it the switch or gaskets, no idea but I did not want to just change the gaskets and have it still leak. easier to change all once and be done (hopefully).
I know something was going as it would loose power and occasionally stall when I depessed the clutch.
It was sucking air into the system.
So, basically an easy fix.
