MarcoPolo
Mud.. it's a life...
I see his engine starting OK but then disaster striking!
Im guessing it didnt turn out to be the barn find of the century.
You boys down under need to come up for some optimism.
Waiting
"I would remove the delivery valves at the front of the pump", WTF? An inline pump only has one set of delivery valves, and they're on the top of the pump. I haven't the slighest idea of what you would hope this would achieve.
I'm with amaurer on this one, alot of people have spoken a lot of crap and probably scared the christ out of you. This is all you need do.
1. Drain the fuel from the tank and replace it.
2. Change the fuel, oil and air filters (check the intake system for crap while your at it).
3. Bleed the fuel system to the head of the pump.
4. Change the oil.
5. Remove glow plugs and lube the bores.
6. Crank it to get some oil circulating.
7. Reinstall plugs and go for gold (you might want to cross your fingers).
This engine is older than the hills and hasn't been run in 17 years, If it goes it goes, If it's stuffed you couldn't possibly be surprised.
4. Change the oil.
Ok... sorry guys... i have been trying to finish 2 houses and i havent had hardly any time to work on it. I did drain the tank under the seat, opened it up and it actually looked very clean. Got fuel all the way to the filter, new oil, new oil filter, i was good to go. Climbed in the cab, cranked on the starter, engine turns over and...........
