Sorry to hear that Brett. I had a similar issue with a different cause a while ago:
https://forum.ih8mud.com/80-series-tech/73390-80-wont-start.html
If I recall from looking at where the NSS harness plugs in, it isn't so much fun to get to that connector.
Man Brett, with all the problems you've been having with your 80 lately, I'm starting to think that the Rover gods are mad at you.
. If you read the FSM, Toyota states that you need to put 221 lbf of pressure on the contacts while tightening up the bolts using a block or wood cut to specific dimensions. Not sure how many people have a press or tool that can do this or the proper tool to insure the contacts are square, but I don't. My method has been to use the handle end (wood) of my rubber mallet to press down on the contacts while tightening up the nuts. Worked fine on my LX when I replaced the contacts in that starter but apparently it didn't work out so well when I did the 80...So one for me, one for the starter contacts. It is a tie until the results are in from my latest attempt. I should know in about 6 months time (less) whether I won or the starter won again...If the starter wins then I may just take the starter and new contacts to someone with a press
