No idea what that plug is for, but traditionally Toyota uses white with black stripe for ground, and green for illumination.
You can hit the little black plunger on the door jamb to shut it off instead of shutting the door.I get the beeeeeeeeep too when I turn the car off and open the door like I left the key in the ignition (if there was one). I haven’t checked to see if the headlights are on Auto. It’s annoying but if I close the door and reopen it stops.
However, the lights should go out after after a set number of seconds even if you don’t lock the car, I think like 30 if I had to guess. But they should also turn off when you hit the lock button twice. Does that happen?
The owners manual says 120kAt what mileage should the spark plugs get changed?
I see some people doing it at 100k and others at 130k.
I just did mine at 121k and I've noticed zero difference in mileage or power. Maybe they'd run 200k or more without degradation, maybe 122k is the limit?
The guys who go dune jumping in the UAE, Saudi Arabia, etc would say you're being paranoid.Sand...how do people feel about driving their LC on sand dunes? There's a big dune park in Silver Lake, Michigan, but I don't know about going. The thought of my truck getting full of sand, some of which I'll never get out, makes me nervous. Sand and moving parts are not a good combo.
Am I being needlessly paranoid?
hmmm..
You got to pay to play.... I'm not taking mine to the dunes... or in a river... not that it can't.I know, I know!
All I'm saying is that the Cruiser ripping through the sand in that video is not the one in my garage. I don't care if it sucked 5 lbs. of sand into the motor and blew up.![]()
I know, I know!
having been to silver a bunch this year:I know, I know!
Depends on what you're towing, and where you ride with the vehicle loaded. I run an aluminum hitch that has multiple drop height options, so I have flexibility.TOWING HITCH QUESTION
Hitch ball drop: standard 2" or do I go 4"?
OEM shocks and springs. Firestone helper bags in rear
Depends on your trailer tongue height. My trailer is low so I had to use a shank which drops 11" (though the top of the ball only drops maybe 7").TOWING HITCH QUESTION
I have the OEM Factor hitch if you want it cheep. It has approx. 4" drop. Can with the vehicle.
Message me if you want it.
My vehicle is lifted so I have no need for it.
