Wanted Split Transfer case Fj60
Still available new. You can also reach out to ValleyHybrids, or Cruiser outfitters and they’ll set you up.
We have 2:1, 2.3:1, etc new cases available but we also have complete good used cases.
What is up with your current t-case?
Thanks Casey, I am specifically looking for a used.
Not completely sure what happened. Had really bad noise on the freeway and it was smoking. After dropping it there was no oil and the teeth were chewed but not destroyed. No obvious culprits so probably just it's time to go. Just hit 309K.
is the transmission overfilled with oil?
It's been awhile since I sold one. What's the current going rate for one of those used ones?
Is the aluminum housing OK? You're right on the split, can you measure and see if you have a 34mm or 38mm idler shaft. That will determine a great deal about parts.
We have new take-out gear sets, full rebuild kits or good used cases (rebuild/reseal recommended). Knowing what you're working with would really help identify options.
I had recently filled it replaced the trans fluid. quite possibly was overfull
The housing seems fine. great I'll measure it tomorrow.
Ive got a complete unit still mated to a 4 Speed out or an 86’
Im out of Los Angeles and can ship via freight.
Let me know
