Thanks
@devo and Jack! You are correct Jack. Before I could get the speedometer cable disconnected, the needle spun off of the speedometer. It is now laying between the glass and the speedometer plate. I cannot tell if it is broken or spun off. There is a shaft on the needle. I will take a photo and maybe you can tell if the needle is broken. I cannot dig into the repair right now, but I will keep your contact if that is ok with you for later work. I have an extra speedometer when I thought my original '69 was broken a few years ago, but a new cable seemed to fix my problem until yesterday. The extra speedo I have is from a later FJ40 model (maybe 72-74) since it has the newer connector, while mine has the pin with the screw cap that goes into the back of the speedo. Maybe I can use some parts from it to fix mine.
