I have found putting a big arse tire on a stock carrier causes a bunch of problems, the least of which is the length of the studs. If you want longer studs use those from the rear of an FJ60 Toy #90942-02052. They are like 1.75" long, about 1/2" longer than stock FJ's IIRC. You could also use any longer bolt or a piece of all-thread rod for that matter. Cut, fit, weld, it all can be done. Because the tire is larger, this can create several other problems. First the weight. Most of the hinges are shot anyway from carrying around a 27-29" tire for 30 years. Put a tire that weighs twice as much on worn out hinges and you got a sloppy mess. I machined new bronze bushing as the OE plastic ones were wasted on my 75. The other problem is that the larger diameter causes the tire to protrude out further on the PS making you have to rotate the tire out to open the rear ambulance door. Pre 75 doesn't apply here but the tire sticking out on the DS can catch on something and you can guess what happens next. Back in the early 80's I saw one take out the drivethu window at McD's. It made a mess of the rear of that 40. It fawked the carrier, hinges, latch, rear quarter, DS rear door and glass. The only real fix is to build or buy a stronger carrier that can handle the bigger tire.
