- Thread starter
- #4,121
Jim, this axle housing is set up to use an early IFS 4runner or pickup front hub, etc., so I'm guessing I would need that bushing in the spindle.
The shaft cant move around like the front, it's fixed on both ends.I can't give the right answer, but they are needed in the spindle to keep the shaft from moving around like in the front.
NO....so I'm guessing I would need that bushing in the spindle.
I would never assume that, I've been given bad advise more than not.I would of thought Front Range knew what they were building
Everything you ever wanted to know and more.....What's the correct way to install this fitting
Rush, none of what I used were metric. I just used fittings or adapters that I had on hand and worked. Sorry I'm not any help on this.the other appears to have metric threads. I plugged it using a (I think) a #12 DIN plug (~18mm). Does this sound right?
YA NO JOHNNY OVERTORQUEEverything you ever wanted to know and more.....
ORB Fittings Explained: From Selection to Setup - Hose Box
Discover the intricacies of ORB fittings. Uncover their varied types, key applications, and gain insights into proper installationhosebox.com
If for some reason you just wanted an answer to your question. Spin it in as far as it will go by hand and get it pointed in the correct direction then tighten the nut with a wrench snug'ish (not farmer tight) we just need it tight and let the O-ring do it's job.
I think I gave all my spare Hydro boost units away so I don't have anything here to check and trying to guess from memory isn't really going to be helpful so I hit an internet search and this is what I came up with.Does this sound right?
Fantastic resources! It looks like there can be many different fitting combinations and between these two sites, there’s an adapter to -AN6 for all possibilities!I think I gave all my spare Hydro boost units away so I don't have anything here to check and trying to guess from memory isn't really going to be helpful so I hit an internet search and this is what I came up with.
Hydratech Braking Systems :: Hose, Fittings and Adapter Listings
Hydratech Braking Systems :: Hose, Fittings and Adapter Listingswww.hydratechbraking.com
From Hydratech's site. This lists all the outlet fitting sizes.
HYDRATECH 9103 AN-6 BANJO FITTING SET
* 2 Piece Design 5/16-24 O-ring Male to 3/8 Male Hose Barb Return Line Adapter
* Surface Seal Type Adapter with O-ring Seal
* 18mm x 1.5 Metric to AN-6 Male High Pressure Inlet Port Banjo Fitting
* 16mm x 1.5 Metric to AN-6 Male High Pressure Outlet Port Banjo Fitting
* Zinc Dichromate Plated Mild Steel Banjo Bolts and Fittings
* Fits most all 1980 and newer Bendix Type I and Type II hydraulic brake assist units
Hydro-Boost Low Pressure Return Spitter to 6AN Banjo Assembly (w/ washers)
Hydro-Boost Low Pressure Spitter Return Banjo to 6 AN Adapterwww.powerbrakeservice.net
We could tell by dem Popeye forearmsI was always taught to " tighten it 'til it smokes ".
Sum bitch! There's a lot going on in there!Oh, I've been staying busy with other messes. I had to replace that gray solenoid on the right and while in there, redid some things. That led to pulling the whole dash apart. Oops, no picture of that mess. Speedhut sent me some new gauges, now my speedo only goes to 120 not 160, guess I'll have to let off the skinny pedal.The fuel gauge was acting wonky, so they replaced that also. A new rocker switch for the air compressor (and fixed an air leak), which is run by that new solenoid. All good now.
All I wanted was to go camping.
