You can get to most of the frame without removing the body. Take a portion at a time. Body mounts can also be done with body on. Lift enough to slide them in.
I was planning on doing this slowly over the winter between school and work. I think I have all the tools I could need. Space is the biggest issueIt’s not a bad idea to pull it…
When I swapped in a new frame it took about 100 hours work. Between pulling the new frame at the wreckers, stripping it, sandblasting, 4 coats of paint, putting the body & front clip, swapping everything to the new frame, and reassembling everything,
Two people would make it faster… but you’re probably looking at a weeks work… or 2-3 weekends. I’m not saying this to discourage you, but just to help you understand it’s not something you’ll have done in one day or even a weekend.
Go for it.
If you’re better equipped and faster than I was when I was in my teens… more power to you.
This is awesome! Totally something I’d do! Had the same HF hoist they work great. I did something similar for an engine swap on my 69 40 in a tight very sloped carport. Hoist up and roll back, very nice shop there and burro saw horses!I didn’t either. I used 4x4’s, an engine lift, View attachment 3750894a floor jack and saw horses to lift it. Hardest part was clearing the 33” tall tires. I figured if the Egyptians could build a pyramid, I could lift a tub. Once I had the frame rolled out I slid the saw horses in and worked on the tub.View attachment 3750896
If it looks a bit sketchy….it was.
Would have been easier if I stripped it down a little more.
That’s what I was gonna say. I wouldn’t take it apart.You can get to most of the frame without removing the body. Take a portion at a time. Body mounts can also be done with body on. Lift enough to slide them in.
You'll likely have most of the tools needed. Take lots of pictures, and there are lots of people here to help.I was planning on doing this slowly over the winter between school and work. I think I have all the tools I could need. Space is the biggest issue
shoot if the shifter is that bad I'll just lift the tub up over it and not worry about itYou'll likely have most of the tools needed. Take lots of pictures, and there are lots of people here to help.
The one tool that can be extremely helpful is a hot-wrench (Oxy-Acetylene torch). When I was unbolting the new frame from the donor vehicle one of the body mounts broke... fortunately, one of the mechanics at the wrecking yard hit it with his hot wrench (since I hadn't brought mine. These days you might be able to get away with a reciprocating saw... but 30ish years ago, I hadn't even herd of them and definitely didn't have one.
With a couple large screw drivers you can remove the stick shift. Ask when you get there... I'd bet there's a video out there somewhere that explains how to pull it.
It’s quite easy… the hardest part is figuring out if it’s clockwise or counterclockwise that the retainer needs to be turned. I haven’t messed with one for 26 years so I don’t remember off the top of my head.shoot if the shifter is that bad I'll just lift the tub up over it and not worry about it
the only thing holding me back is the fact that I don't have a lift. Plus the axles would be pretty much out anyway to do the lift.
Or the Darwin Award thread. My first thought was to hang it from the rafters, but the wife vetoed that oneYou should cross post this to the redneck thread
Nice job....gave me some ideas for my upcoming teardown
I agree… I have replaced the frame, disc brakes on both ends, built a rear tub, SBC conversion, onboard air, transmission swap, rebuilt a hardtop, Scout II P/S conversion, and a ton more.You dont need a lift
There's nothing about that job that two people cant do......you'll need an engine hoist/jacks etc but there's nothing difficult about the job
I really need a gantry crane......Or the Darwin Award thread. My first thought was to hang it from the rafters, but the wife vetoed that one![]()
I have all that minus the engine hoist and stand but I can snatch one from schoolI agree… I have replaced the frame, disc brakes on both ends, built a rear tub, SBC conversion, onboard air, transmission swap, rebuilt a hardtop, Scout II P/S conversion, and a ton more.
All of which I’ve done solo and most of which I figured out on my own without outside help.
Done with basic tools plus an engine hoist, floor jack, and an engine stand.
A welder helps too, Most was with oxyacetylene, then stick, and most recently mig.
