Should I replace my radiator? (5 Viewers)
Interesting video. FWIW I once considered rebuilding my OEM radiator years ago as the core was (and still is) in perfect condition but once I priced out new top and bottom plastic tanks along with the O-rings (rubber seals) and the plates (rectangular metal rings) it was getting close to the cost of a new OEM radiator even with reusing the transmission cooler in the bottom tank.
It's all moot now AFAIK most of those OEM radiator parts are NLA except for the drain cock, it's small O-ring, and the radiator cap, unless there's an aftermarket source for those parts??
The concerning question is the cause for the overheat and possible over-pressurization that may have caused the leak??
Is the leak just due to a hose/hose clamp, or a hairline crack at the base of the top tank, or a failure of the O-ring for the top tank (?rare), or a defective T-stat or cap??
Or is the head gasket leaking and blowing pressurized exhaust gases into the cooling system/water jacket??
For historical purposes:
Snapped some pics. Cleaned everything up tonight and will see how it looks over the next week or so. I noticed when I got back from work that the coolant reservoir was about 1" above the fill line. By the time the evening came, it was back "normal" and at the fill line. I"ll check to see where it is at in the morning before I leave for work. Appreciate the input thus far!
these are the last two pics. all the hoses seem to have normal feel, not stiff. They were replaced within the last couple of years, I'm digging through receipts to see what I can find.
What was actually cleaned??
You're not wrong though...
@simpsoap You need to clean up all that red residue so you can actually see if any new antifreeze is coming out. All of that came from somewhere. That last pic looks like it might be coming from around that upper hose, but it's just hard to say where it migrates while you're traveling at speed.
These were the pics before I cleaned off all the crusty red residue. Another member posted that they wanted to see better pics so I snapped some before I got started. Figured if I sent pics after the fact with stuff looking "wet" it wouldn't do much good. I'm going to watch things closely and see if I can determine a cause.
Man, those Radiator Hoses look excessively swollen to me through the innerwebs. Also, the return hose at the top of the Radiator seems to be at a harsh angle to meet the Radiator connection, and I've always tried to mount them so there's zero tension on anything, given their plastic connections and the engine moves within the mounts.
Personally, it looks to me like your top tank gasket has failed - or is failing - and while it may be holding pressure at the moment, all of that pink crust is Toyota Red being boiled out, and when the moisture is gone, you get that residue. Those pictures are the MOST residue I've ever seen on a Radiator top tank.
I don't want to scare you, but I live in the Sonoran Desert and can't have anything affect engine heat oror A/C function. I'd park that thing until my new Radiator came in, and then I'd do full Radiator Hose replacement while it's out,... but that's me.
You should be smelling the sweet, acrid smell of Toyota Red if you have that much seepage. Open your hood after a drive, and I'll bet your eyes water. If you're smelling coolant, there's an issue to be addressed.
excellent observation amigo, and I'm with you. As an aside, the Sonoran Desert need to be revisited by me as that place is muy maravilloso, as they .
I bet after the engine is hot, and the OP sprayed a bottle of soapy water around the top perimeter of the radiator, he'll see bubbles.
I didn't see any bubbles last night when I sprayed things down, but I will spray things down again once I get home. I am still surprised I see nothing on the ground, and the overflow tank doesn't seem to be losing coolant. Wouldn't it be sucking coolant into the system if it was constantly losing coolant?
To be honest, I have never noticed the smell of coolant, but I will start checking. I believe when I had the head gasket redone at 292k they replaced the hoses and radiator, but now I'm curious. If they didn't then you are correct, it is probably time to replace those. I replaced the fan clutch at 303k due to a noise.
-Andy
Hey Andy
that leak is old and quite possibly has sealed itself with the solids that fell (precipitated) out of the coolant over time. This happens and it tells us that your coolant is seeping out of tiny leaks. This is what "radiator stop leak" does and should only be used as an emergency to return home from the bush. So, keep a bottle of Bar's stop leak pellets in your spare kit for emergencies. It also stops HG leaks, if you can believe that!
This may not be too relevant, but I did notice that your radiator cap is set for 0.9 bar. If I recall correctly, you can get them for 1.1, but I'm not sure what the spec is. In theory, a higher pressure radiator cap might allow it to cool more.
Also, the blend of coolant will make a difference. More water usually cools a little better, but freezes more easily. Can be a balancing act.
That said, it sounds like your cooling situation is borderline, and it probably shouldn't come down to such a minor detail.
I am curious though what the stock radiator cap setting is, and if some run higher or lower numbers than that.
That upper hose does not look like an OEM hose. I'm thinking the poor fitment angle might indicate the hose was not properly installed meaning the current hose end at the radiator should have been installed on the engine side.
Got home from work and sprayed water, didn't see any bubbles coming from the top, and everything still looks nice and clean.
As for the hose you mention, hoses were replaced at 292k with OE Toyota hoses, the only thing I can suspect is that when the head gasket got redone they bought cheap hoses or like you said, it is installed incorrectly.
I plan to keep watching the radiator to see, but at this point it might be worth getting all OE hoses, getting them installed properly and going from there.
In practice, a higher pressure radiator cap might also allow it to leak more! 😁
I would definitely get replacement Radiator Hose Set (*I like [Removed, no longer supported vendor] ), and start shopping for a Radiator and searching the numerous threads to help you make the right choice. There's a solid argument for OEM, as it comes with the correct foam strips to seal airflow for best performance, but there are also aftermarket options (TYC-1918) that also work well.
You commented a few times about having this work done by someone else. Is it work you're willing or able to do yourself? Can you find a local shop that specializes in LandCruisers? You'll get much better performance and peace of mind if you go with an experienced mechanic (*If that's not you...),
After weaponizing my autism (!), I noticed this tiny detail: the Radiator Hoses have threaded fiber reinforcements inside, and you can see these as white threads visible on the cut ends. On yours, these are stained with Toyota Red, likely because the hose has deteriorated internally and allowing the coolant to pass through these threaded cords.
See the pink cords? Those should be white. It's possible that the coolant from the top tank seal is soaking everything, but it's just another indication that your Radiator Hoses definitely need to be replaced, along with the Radiator. Anyway, back to it,
Absolutely! Certainly a tradeoff there.
I would definitely get replacement Radiator Hose Set (*I like Wits End, a supporter on this site), and start shopping for a Radiator and searching the numerous threads to help you make the right choice. There's a solid argument for OEM, as it comes with the correct foam strips to seal airflow for best performance, but there are also aftermarket options (TYC-1918) that also work well.
Absolute Witt's End went bankrupt after scamming a bunch of people. As a former customer, I don't think it'd be wise to recommend the business, nor the successor. That said, the part collections were fantastic and he had a lot of great stuff. Having to email a month or more after an "in stock" order to actually get it shipped was not, however.
Thanks for that, I didn't realize there was a problem, and appreciate you setting it straight!
