I used a regulator between the compressor tank and the air solenoid manifold, but I had a York OBA setup in that truck. I have the same OBA system in my LX450, but I have factory lockers. Personally, I think ARBs are the way to go. I still don't understand why folks pay a premium for factory lockers. They're annoying.
According to the regulator I have on the Locker Manifold my ARBs don't shuttle until 95-100 PSI. I set my OBA up at 120 ON/150 OFF and a 175 blow off valve.
Where I'm going with this is, if you limit your system to 70-100 psi, your ARBs may not reliably cycle.
That has not been my experience with ARBs. I ran 68-70 psi for many years, and there was never an issue. If you drop below that, it became intermittent.
or better yet, get a jeep for rock crawling. I expect dude like him to have more pride in American made product...lol
I will save that for when he blows his HG...lol
No sir not yet. I’m sure I’ll put time into it over my next four days off beginning Friday. I did some interesting reading yesterday in some older threads and also newer about building a front 9.5 using the rear housing from a 60. But that’s another thread because I would want to hijack this one.
Harrop says in this video.... "A misconception that the locker will not stay engaged when changing from forward to reverse movement....."
"However the reality is that while there is load on the differential in extreme conditions the axles will in fact remain completely locked."
By this wording, I guess it leaves open the possibility that if you release the brake or throttle or do something for it to become unloaded when shifting or changing gears or rolling backwards while in gear, then the diff can/will unlock?
To keep it all Toyota use a semi float rear axle from a 91-92 and weld on the knuckle balls from a standard 80 front axle like @raisinghell2 did on the front axle of his all Toyota DNA Buggy
Yeah, posted that video earlier. Madmatt does a good video where he goes into more detail on this and his experiences with it:
He also talks a lot about an issue he had with a failure case, which like the ARB seals issue above Harrop have subsequently replied to, and put down as a known issue with a bad batch.
