Work has been progressing slowly. But the pace will be picking up. I've been disassembling, inspecting, cleaning and recondition parts. I've had a steady stream of parts rolling in over the past few weeks started with a Lexus 06 GX470 w/98K engine.
I held-out as long as I could looking everyday locally for the replacement engine. But ultimately found a fresh engine out in WI, with as good a maintenance history from Lexus as one could hope for. The GX470 had timing belt, water pump, coolant and LOF done Dec 2017 ~600 miles before a fairly minor rear side impact totaled it. Strangely they didn't replace T-belt pulleys or tensioner. Interest only T-belt idler pulley was replace in the 07LC engine with Timing belt & water pump. For some reason these dealer on the Eastern half of the country don't feel they need replacing. I called both and they said these pulley's and the tensioner last forever.
So I've order new Tensioner and pulleys for Timing belt, as I'm not comfortable with old. I'm also replacing fan bracket and fan fluid clutch. Along with various gaskets and seals. In addition I'm having
Fuel Injector Specialists - Home - Wheat Ridge, CO Clean, rebuild and test the fuel injectors and replace Fuel Pressure regulator as and extra.
Being a GX470 engine, I've had to swap out or replace many parts from the 07 LC engine or buy new OEM. Here a partial list:
Various wire housings.
Oil pick up tube (pan to pump).
Oil pan #1
Oil baffle
Oil pan #2
Oil dipstick.
Oil filter bracket
Oil cooler.
Hose from block to oil cooler.
Oil cooler front pipe and various hoses.
Motor mounts.
Main battery/starter wire harness.
Exhaust manifold
Main engine wire harness.
Fuel line (filter to fuel rail/damper device)
I've spent a great deal of time tearing down, inspecting, deciding what part I'll need, acquiring/order parts, parts and machine shop runs and checking/inspecting new parts.
Here's a parts plus stuff of about 250 items, which I'll come in at ~$6K before done. It will likely grow to around 300 items before done, and does included the swapped parts.
Machine shops Quantity Component
250 Total number of items Parts
var 150 Miles Miles driven for parts & Machine shop
3/21/18 1 Engine 2UZ-fe Vvti
4/2/18 1 Shipping Shipping
8/31/17 0.2 FSM Pro rata
1/15/18 0.5 Window wash Fluid top off from shop
Engine
4/6/18 1 17801-50040 Air filter element
Drive Belt
1 National 203-ff Bearing, tensioner dri belt
1/18/18 1 OEM Idler Pulley & bearing
Spark plugs
4/5/18 8 SK20R11 Denso SK20R11
Fuel
4/6/18 1 23300-50090 Fuel Filter engine compartment
3/22/18 1 77285-60540 Clamp,3 Fuel tubes below brake master
11/27/17 1 77169-33020 Gasket, Fuel Suction Plate (fuel pump to tank)
Fuel rail
4/6/18 1 23280-50050 Fuel Pressure Regulator 2004-07
8 23291-41010 2329141010 INSULATOR, INJECTOR VIBRATION
4/6/18 1 23232-41081 23232-41081 (GASKET (FOR FUEL PUMP HOSE to damper))
4/6/18 1 90430-12026 90430-12026 GASKET(Fuel hose to rail held damper union bolt)
4 90430-12026 90430-12026 GASKET(Fuel crossover pipe to rails) 4)
4/3/18 8
Fuel Injector Specialists - Home - Wheat Ridge, CO Fuel injector clean rebuild & test
Intake manifold
3/30/18 2 17171-50030 Gasket intake manifold to head (2)
4/3/18 1 22271-50050 Gasket, throttle body
Vacuum Hose
4/5/18 1 23829-50161 2382950161 HOSE, FUEL VAPOR FEED
4/6/18 3 90999-92003 Toyota Vacuum hose 2' section
AI
3/30/18 1 17342-50180 Hose AI No. 2 (longer RH water)
3/30/18 4 17377-50010 GASKET (4), AIR TUBE, NO.2 (switches)
3/30/18 2 17376-50010 GASKET (2), AIR TUBE No 1 (Exhaust)
Oil
3/30/18 1 15692-50020 O-ring (figure 8, filter bracket to oil pump)
3/30/18 1 90301-67004 O-ring (large FOR OIL COOLER)
3/30/18 1 15777-50030 Return Hose
1 Oil Filter M1 filter
Oil pan
4/5/18 6 5W-30 Advanced Auto syn for 15min warm up with ERP BG oil flush
9/1/12 8 M1 5w-30 Oil
3/30/18 1 90430-12031 Gasket, Oil plug Drain washer
3/30/18 1 96721-19010 O-ring, oil dip stick guide tube to pan
3/30/18 1 15147-50011 GASKET, OIL STRAINER (pickup tube)
3/30/18 1 00295-00103 FIPG 1207B Sub is 103
Exhaust
4/6/18 2 90080-43036 Pipe Gasket
4/6/18 1 17198-50010 GASKET, EXHAUST MANIFOLD TO HEAD, LH
4/6/18 1 17173-50030 Gasket Exhaust Manifold , RIGHT
4/6/18 16 90179-10070 16 Nuts exhaust manifold (non reusable). 9017910070
4/5/17 0.4 Optimum Gray FIPG
Timing Belt
4/5/18 1 13503-0F010 13503-50011 Idler pulley (Koyo
4/6/18 1 13505-0F010 13505-50030 Tensioner pulley assy (Koyo)
4/4/18 1 13540-50030 1354050030 Tensioner (Asisin BTT-505)
Alternator
1 27411-0A050 Pulley
PCV
4/6/18 1 12261-50070 Hose, PVC DS
4/6/18 1 12262-50080 Hose, PVC PS
Engine clips
90464-00301 Clamp, hold one line to another smaller line. PS front of engine
3/30/18 1 BG 109/115/208 oil flush, treatment & 44K
1 44K Can added to gas (shop can)
3 Coolant SSL pink 50/50
1 Dist. water Dist. water
1 08826-00100 Seal packing or equivalent (shop supplies pro rata)
4/5/18 1 90916-03100 Thermostat
4/5/18 1 16346-50010 gasket, Thermostat-Water inlet housing.
4/4/18 1 16210-50102 Clutch, fan May 05-07 VVTi (Aisin FCT-075) Amazons looks good
4/5/18 1 16307-0F010 Bracket, fan (Aisin FBT-002)
Radiator
1 CU2755 Spectra Premium
4/5/18 1 16401-67150 Cap
Heater tee's
4/6/18 2 87248-60460 Plastic OEM tee's
Water by-pass
4/6/18 1 87245-6A220 87245-6A220 HOSE, HEATER WATER, INLET A Bypass to tee inlet to core
4/6/18 1 87245-6A191 87245-6A191 HOSE, HEATER WATER, OUTLET B Tee out to bypass pipe
3/30/18 2 16341-50020 GASKET(WATER BY-PASS JOINT, REAR & front 2 each)
3/30/18 1 96761-24019 O-ring, PIPE SUB-ASSY, WATER BY-PASS
Drive train
3/16/18 1 Propeller shafts & spiders Grease shop supplies
Transmission
90301-15004 Ring, O (Transmission Case Adapter sub-assembly fill Plug)
1 35178-30010 Drain & level check washer
4/5/18 12 00289-ATFWS Qts. WS ATF
3/30/18 1 90080-31068 SEAL, OIL (FOR FRONT OIL PUMP) (old 90311-38083)
AHC
2.5 08886-81221 Suspension Fluid (2.5qts from shop)
9/28/17 5 49177-60010 AHC accumulator bleeder cap
Transfer case
3/16/18 2 90430-A0003 drain and fill washers
1.5 Qts. M1 75w-90.
Rear differential
3/16/18 2 12157-10010 drain and fill washers
3/16/18 3.6 Qts. M1 75w-90
Front differential
3/16/18 2 12157-10010 Gaskets, drain & fill washers
4/5/18 1 90311-47013 Axle seal, LH
4/4/18 1 90311-47027 Axle seal, RH
1.8 Qts. M1 75w-90
4/6/18 1 41651-60010 Cushion, Differential (front press in)
4/6/18 1 41653-60010 STOPPER DIFFERENTIA (front top cushion) (Febest TAB-334)
4/4/18 1 41653-60020 STOPPER DIFFERENTIA (RH rear top cushion) (Febest TAB-335)
2 90105-12240 90105-12240 Bolts, #3 crossmember plus side bracket (4)
Front Drive shaft
4/6/18 2 43430-60040 Axle Assembly
2 90521-34003 SNAP ring (DIFF SIDE GEAR INTERMEDDIATE SHAFT) 90521-34003
Steering knuckle
4/6/18 2 90316-A0001 Oil seal (inboard)
0.1 Shop Supplies grease
0.1 Shop Supplies Marine grease
Axle Hub / Wheel bearings
4/6/18 2 43421-60060 Hub Flange
2 43422-60070 Hub Flange gasket
2 90311-70011 Hub seal
4/6/18 1 90214-42030 Claw washer
2 90215-42025 Lock washer
4/6/18 12 42323-60030 cone washer
4/6/18 2 90520-31007 snap ring 2.4mm. Hub flange D
0.3 Shop Supplies Solvent
1 Shop Supplies Wheel bearing grease
Power steering
1 ATF Qts M1 MV full syn ATF
3/16/18 1 44327-30040 Hose & tube assembly LH gasket, Power steering HP line 03-07
3/16/18 1 44327-30030 Hose & tube assembly RH gasket, Power steering HP line 03-07
4/4/18 1 TAB-UZJ100-KIT Steering rack mounting bushings, (Febest rubber) Quality iffy)
4/6/18 1 17030-50150 Vacuum hose assemble
4/6/18 1 44348-60320 Power Steering Suction Hose
4/6/18 1 44412-60280 Power Steering Return Hose
Brakes
10/11/17 4 31478-30010 Cap, brake bleeder rubber cap
3/16/18 4 93319-15008 Screw w/washer ABS wire leads
3/16/18 4 94130-60500 Nut, ABS wire leads
Body
4/6/18 2 Hood Lifts Monroe Max
Amazon
7/1/18 3 wash/cleaning Shop
10/5/17 1 Paint detail 1F7 Sliver
4/6/18 1 81561-60680 LENS & BODY, REAR COMBINATION LAMP, LH
Interior
1 Carpet Carwash shampoo at car wash
1 Driver floor mat stay & carpet grommet
HAVC
4/3/18 1 88891-60040 Cover, Cooler unit, face plate w/filter door hatch
4/3/18 1 88891-60060 Door, cooler unit face plate door
4/6/18 4 90948-01003 Cushion, link
4/6/18 2 94184-61001 Nut, link top
4/6/18 2 48820-60032 link w/bushing lower pressed in
4/6/18 2 48815-60111 Bushings, Stab Bar
4/6/18 4 48817-30010 cushions, link
4/6/18 2 90385-11021 Cushion, Bar to link
4/6/18 2 90560-10275 Collar, Bar to link
4/6/18 2 48815-26250 Bushings, w/AHC
Brakes
3 DOT 3 or $ synthetic
2 spacer, Rear Spring
I've pulled more parts from the Unicorn than I ever have from any rig, much-less all at once. I got stuff stuck in every nook and cranny.
