Scored 2007 LC w/174K AHC (1 Viewer)
I got an LX470 07 which has LSD in the rear DIFF. Do I have to use the special LSD DIFF oil or I can get away with the same oil in Front & Rear Diff and mid-transfer case? My car is at the shop right now for some maintenance and they said to bring in Toyota Transfer case oil and LSD diff oil.
I use Mobil 1 75-90 which is an LS (LSD) gear lube. I use in front & rear diff and transfer case. If in very hot desert, you can go with higher weight (viscosity)
Thank you 2001LC. Also, thank you for this post - I have bookmarked it so I can learn from you and do my own PM.
Pretty cool. I got so motivated that now thinking should probably keep the latest purchase and do all the maintenance first.
