Hey Mark, I thought I'd pick your brain on this... I can buy a '72 350 out of a C10 that has 72k miles on it for a reasonable price. If I put my RV cam in it with a SP-2P-2 manifold and either the newer 1406 Exelbrock or stock Quadrajet... how will off idle torque be?
I believe I've been running 10:1 compression and the 72 is likely around 8.5:1. I don't want to be disappointed in how it works. Thoughts anyone?
I've got a good Wolverine Blue Racer RV cam from about 1997 before Crane bought them out... I've never been unhappy, and I don't care about hot rod performance... it's a tractor after all. I'd be disappointed if I
Saw a dramatic decrease in fuel economy... but hp doesn't matter.
I'm about to start on my second 70s motor and I'm just as interested as ever.
As for how fast... the last motor easily hit 95 mph and I decided that was too fast for a 40 and I didn't care to find out it's top speed.
I'm not Mark, and I wish I could answer the off-idle torque question, but:
The setup you had was a high compression, bigger displacement version of my own. My 283 SBC/RV Cam/SP2P/Quadrajet was running about 8.5-9:1 compression. It was not, by any means, a power house, but it was sufficient to move the truck around. I had belt alignment issues so I wouldn't push it past about 3300 RPM, which was sufficient to get the truck to ~70mph on 31's, so spooling it up over 4000RPM would have taken me up into the 80's or low 90's most likely. (I never tried, I also determined that anything over about 65 is too fast for a cruiser).
Keep in mind that an SP2P is an intake that was built solely for fuel economy. It's got tiny runners which gives it great throttle response but it is in no means a "performance adder" over even a stock chevy intake. It falls flat on its face at about 4500rpm - can't flow any more air. I like it, and it was a great match for a 283. I will be transferring it to my 350 unless I decide to go with a later-model one-piece main seal style.
I know I mentioned it to you previously - but I think this setup was getting ~13-14mpg highway. Getting 17mpg in a brick-shaped object in a mildly built engine is impressive. Especially when I know your truck's tub is actually so thick it could protect you from small-arms fire.
