Now there's a real practical off-road crawler motor.View attachment 1527236 I have a fresh 383 stroker, this would be an upgrade!
Sand drags (with a filter), absolutely.
Would love to give you a hand if you were a tad closer. Even if to just get out of this Redding heat for a few days.
That sounds like a piston following behind.![]()
Unfortunately auto wreckers here demand a premium for everything. For reference, they wanted $1500 for a decent runner SBC. I could likely buy a donor for less and sell the spare organs to recover some.Junkyard ls swap, gm flywheel spacer and everything else is easy....50 year newer design, and cheep.
I think Bikersmurf already tried to explain he is not in a position to spend money unless it is absolutely necessary.
A vortec will cost hem more in Canada than it would in the US.
If I had to buy a Vortec it would cost me over 5k€ Where I can buy a complete Lexus with good running v8 for 1,5, just to say things are different in other areas of the world.
Sometimes the best option is the cheapest.
Might want to look at Northern's site, just a thought.
I've decided against the 283. I'd rather rebuild mine... and so far it looks very rebuildable. '416' heads from a 305 would solve a lot of the limitations of the powerpac heads.
I don't care about the top end number... but the idle torque I'd miss. It would chug along at 10 mph at idle without protesting.
Unless I'm mistaken, I've got a solid foundation to build on. Decent heads, a 69 block with minimal wear, flattop pistons, and a spun rod bearing or f'd up rod. Worst case I'll likely need a rod, Crank, and a bore... throw in a rebuild kit and I'll be back in business. So for next summer (or winter). I'd have a healthy motor for another 50 years.
