I discovered the other day that my vacuum advance wasn't working anymore so I started looking for replacement parts/units. After core deposit, Napa's remanufactured units are about $140, which seems reasonable enough. I only need the vac assembly, but the only place I found one was on SOR--used for $75. Did a little searching and found this:
https://forum.ih8mud.com/40-55-series-tech/281609-vacuum-advance-repair.html
VERY helpful. I tore into mine, figuring that a core is a core and I didn't have much to lose. I found that my vac diaphragm was intact, but the rubbery sealant was pealing off the cloth. A couple minutes with a can of carb cleaner left my diaphragm looking like this:
And after a coat of spray Plasti Dip it held vacuum and after four coats it was flexible, held vacuum, and looked like this:
Re-crimped the assembly, returned it to the dissy and reinstalled the distributor. My truck has never run better. I hope this might help someone else who's starting to notice their vacuum advance isn't what it used to be.
Now I have one question about hooking it up to the carb. I had a feeling that I might have hooked it up to the wrong vac port so I hooked my vac tester up to the various engine side ports and watched the dial from idle on up. The one closer to the headlights has zero vac at idle and slowly generates vacuum at higher engine speeds up to about 5", and the port closer to the taillights has no vacuum at idle (both ported obviously), and quickly generates idle up to about 15" in the same rpm range. Which one do I use? It's a '78 Aisan. Cheers, Duff.
Of course, killing hours searching the FAQ is a reward in itself. Ha, ha.
