Builds SAS 89 Mini--Triple cased Mashed Potato (5 Viewers)
looking really good! i like the hidden fender bars a lot.
Just a thought, but do you have sold body mounts? Cage is ties to frame rigidly, body IF sitting on poly or rubber bushings will flex and may cause more harm than good if welded to the cage.... now if it is still mounted hard like when you had the internal cage then you should be good, otherwise I'd watch for cracked welds or torn inner fenders.
That aside I think it looks b!tch!n'!! Love the 39's
The body will flex some, I expect that and have even considered tying the cab into the roll cage further. But, it sure as hell wont flex like the old cab did with the rear cut out. I had stress cracks all over the place and it was just a matter of time before it disintegrated. It's turning out that the rollover at AOP has been both a good and bad thing, I guess.
Big tars make everything look better.
thanks guys, Honestly I've been on the fence up to this point and even wished I'd done it a little differently but the 39s really pulled it together for me. Now that I've finally seen a fender go on I'm really starting to like it and once i get everything back on like the tool boxes and Hi-Lift I trust it'll finally look "right."
Anyway, the beauty will be in how it performs. I'm holding on to the 37s for awhile until i know the thing wont blow apart like a shotgun to a twinky.
I think it looked better on 33's :flipoff2:
or
  1. exo above cab
  2. fender tubes
  3. complete X behind cab
  4. Sheet metal bed
  5. install passenger seat
  6. new master brake cylinder and bleed
  7. new battery
  8. swap spare tire to beadlock wheel
  9. spare tire carrier
  10. mount tool boxes
  11. mount hi-lift
  12. mount C02 tank
  13. paint hood
  14. paint cage
  15. purchase & install tail/brake lights
  16. rewire and reinstall backup lights
slowly knockin things off. Most of the heavy fab work is now complete. Finished up the Exo over the cab this evening and got one the tail light housing made. :clap:
Light was supposed to be red, oh well. :bang:
Startin' to see light at the end of the tunnel. Brakes done, brake lights done, Exo done, actually got 4 rock lights wired up and working. Damn those little things are bright, 2 more to go.
Then to get to storage. I dry fit 2 ammo cans--nope, need a plan B.
Actually took it for a lap through the neighborhood, first real drive since the roll. Thinkin I'm gonna have to out a steering stabilizer back on cause the death wobble started kickin in around 20-25(?), woohoo!! :(
still lots to do but it's becoming manageable I think.
forget that stabilizer, drill that steering box and get a ram. Hydro assist is oh so nice, you'll want to DD it again... or not lol.
Yup, not the first to say it and for some reason I just can't keep this one in my head but you're absolutely right.
Next weekend hopin' to have 10,000 lbs of love to install.
Damn fine job master Kinze, When's the propane swap gonna happen?
He Means F O O O L Injected!!! :lol: :smokin::smokin::smokin: :lol:
And yet he still follows me around the cove. :moon:
Anyway. I'm closing the gap on completion. Starting to actually think I may have a little extra... nope not gonna say it.
  1. exo above cab
  2. fender tubes
  4. Sheet metal bed
  7. new battery
  9. spare tire carrier gonna use the old one for this trip
  11. mount hi-lift
  12. mount C02 tank
  13. paint hood
  14. paint cage
Add ons / Forgot to mention
  1. Fabricate harness mount - we all know we need these
  2. Install new HAM antennae
  3. check TC fluids
  4. tear down RR beadlock and apply Bead seal to inner bead
  5. Grab handles inside cab
  6. connect dome light inside cab
New under bed tool box is done and Ammo can boxes mounted.
24x13.5x8
So just to show the tail/stop lights. Like said earlier they were supposed to be red but there was a screw up. Anyway, bright.
Thoughts?
X2O-10K Waterproof Wireless Winch Gen2 - $399
images.ashx
  • Waterproofing: IP68 Rating
  • Rated Line Pull: 10,000Lbs (4,545kgs) Single Line
  • Motor: 6.6hp Series Wound
  • Control: Remote Switch, 12’ (3.7m) lead
  • Gear Train: 3-Stage Planetary
  • Gear Ratio: 218:1
  • Clutch: Sliding Ring Gear
  • Brake: Automatic Out-Of-Drum
  • 99 lbs.
So the amount of feedback was quite overwhelming, thanks for all the input guys. :flipoff2:
picked up the X20 this afternoon.
:flipoff2::flipoff2::flipoff2:
impressive Ted !!!!!
Ted, mine is older, but never a problem. I think they are quite a deal!
Updated list and recapping approx completion dates for own memory.
Edit 12/18/14
Edit 12/19/14
  1. install new cab 11/1 - 11/8
  2. Reinstall sun roof 11/11
  3. exo above cab 11/15 - 12/7
  4. fender tubes 12/1 - 12/7
  5. complete X behind cab 12/7
  6. Sheet metal bed 11/26-28
  7. install passenger seat 12/16
  8. new master brake cylinder and bleed 12/6
  9. new battery 12/6
  10. swap spare tire to beadlock wheel (New Tires instead) 11/29-11/30
  11. spare tire carrier gonna use the old one for this trip
  12. mount tool boxes 12/14
  13. mount hi-lift 12/14
  14. mount C02 tank 12/18
  15. paint hood 12/18
  16. paint cage 12/7
  17. purchase & install tail/brake lights 12/6
  18. rewire and reinstall backup lights
  1. Fabricate harness mount - we all know we need these 12/15
  2. Install new HAM antennae 12/13
  3. check TC fluids
  4. tear down LR beadlock and apply Bead seal to inner bead
  5. Grab handles inside cab 12/17
  6. connect dome light inside cab 12/17
  7. Purchase and install winch 12/13
  8. Tune CB 12/17
  9. Purchase/ and install new CB antennae 12/11
  10. relocate and mount Gas filler neck 12/14
  11. Reconnect cut wires from fender and bumper trim Not gonna worry about, think they're turn signal wires so no need.
  12. Trim bumper 12/13
  13. Open front wheel well fenders 12/14
  14. Trim back front and rear of sliders 12/13
  15. Finish capping sliders and frt. bumper 12/19
  16. Finish up rock lights 12/16
  17. Clean up wiring under passenger seat
  18. add 12V remote power behind pass. seat. 12/6
  19. Remount fire extinguisher 12/19
  20. Clearance front wheel wells
look'n like I need to get a new spare for the trailer before New years. :bang:
maybe it's just the Rum talkin but it's a good thing Amazon doesn't carry these or they'd be on their way already right now.
A little Retro 80s throw back for $25
