It says it's safe to paint after 24 hours, should be close enough.
Ospho it is! I cut away the carpet and it has spread only about an inch from the hole, so should be easy in comparison....Unless you neutralize the rust cleaning it up and painting is just going to slow it down a little bit, it'll come back.
True! But I know the problem is a broken drain line half way down the pillar (the pillar my left leg sits under, tried of wet jeans) thus it is not worth it to me at this point to tear apart the entire headliner and pillar to truly fix it. Just needs a fix that will make it to the point I cam do some interior restoration. Your not going to like it but ruin the paint and seal it 2.0 has begun! In true redneck style, Im going clear flex seal over top of the 2 lines of silicone already in place. Then using a tape (yeah that's right tape) that should be able to hold up well to the elements and UV to complete the final layer. Decided on the tape after the edge came with the tape on the glass side (see pics)Maybe pull the front door kick panels, access the drain tubes and extend them down through the rocker panels so they dump to the outside?
Sealing the sunroof is asking for trouble. It was never meant to be sealed. It needs to drain.
True!! But after silicone, flexseal, and some specialized tape I believe I have done it!Maybe pull the front door kick panels, access the drain tubes and extend them down through the rocker panels so they dump to the outside?
While you are at it, spray some soapy water on the outside of the windshield around the gasket, then blow compressed air against the edge of the glass from inside and watch for bubbles. I had a 6" area around the upper driver's side that wasnt sealed that water would come through, run down the edge, and spill into the same area you had the rust. Because it was high on the windshield, it would only be an issue if I drove in the rain and made it impossible to find until I used the soap/compressed air. Some polyurethane sealant inside the seal solved the problem. HOW TO: Fix your leaky windshieldTrue!! But after silicone, flexseal, and some specialized tape I believe I have done it!
I am worried the windshield is leaking as well! Few weeks I'll have time to discover more problems!While you are at it, spray some soapy water on the outside of the windshield around the gasket, then blow compressed air against the edge of the glass from inside and watch for bubbles. I had a 6" area around the upper driver's side that wasnt sealed that water would come through, run down the edge, and spill into the same area you had the rust. Because it was high on the windshield, it would only be an issue if I drove in the rain and made it impossible to find until I used the soap/compressed air. Some polyurethane sealant inside the seal solved the problem. HOW TO: Fix your leaky windshield
. I'll let you know how it goes.I do have some bright silver reflective aviation tape. It would definitely up the cool factor!@TheWhitefox why didn't you use silver tape around the sunroof. All the cool kids do that.
@JohnVee can show you how to apply it properly.I do have some bright silver reflective aviation tape. It would definitely up the cool factor!
