NLXTACY
Wits' End
I am using Toyota 23221-46110 Supra fuel pump. But there is enough of a difference that I need the mud illuminati to get involved. As you can see from the photos, the bottom of the original and Supra pumps are different enough that I can't use the rubber isolator for one. The height of the pump means it pushes against the outlet pipe and there is no connector.
So I need to find out if I'm supposed to be adding eyelets to attache the electrical? So I bend the tube to allow for more clearance? Do I remove the rubber isolator?
Help?!?!?!
Help?!?!?!
