No black or white smoke. Tire pressure is good, I kept an eye on that regularly on the drive down. Breaks aren't dragging (I can easily roll it by hand). The fluid in the transmission transfer case and both diffs is all new Redline. Mt90 in the trans/transfer case and shockproof in the diffs.
The developing theory is that the injector pump is having trouble pulling fuel through the raycor and is running lean. That would explain the lack of power but not the massive fuel consumption. It is also a naturally aspirated four cylinder diesel, there isn't going to be a lot of get up and go. Tons of torque yes but not a lot of speed. Also our top speed is about 80kph, down hill, with the wind at our backs.
I would love to test the injectors. I did the timing twice to make 100% sure that it was right as far as timing it to the crank and camshaft. There is a little bit of adjustability in the pump (you can rotate in relation to the motor). It may be off there. There is almost zero smoke when the truck is running, even when it starts cold.
the only thing I can think of would be timing or the injector spray.
I'm not that familiar with the inline pumps like your 3B has, but I know with the rotary pumps, even when the timing gear (or belt on some) is all setup right, the pump still needs to be timed on the engine. Like a distributor in a gasoline car. The rotary pumps use a dial gauge indicator that gets mounted on the pump. The timing is really critical. If your engine starts easy and there is little smoke, it could be that your timing is too far advanced. Does the motor sound pretty rattly? Too advanced will be fighting the piston on it's way up and thus give worse economy.
Just let me know what works for you as far as testing your injectors go. If they need a rebuild, that is relatively simple too. As long as you can source some new Denso nozzles ok. Did mine a few months ago and it worked out well.
