I bought one but your dad has one at the hanger.Where did you
Find a soldering iron?
I've got dual batteries for it so I'll try that tomorrow.I had a lot of trouble starting mine off just one battery it would crank but just dident have the speed to start cold. Also if you removed the edic motor the swing arm on the pump typically gives it extra fuel while cranking. That arm also shuts the fuel off in the forward position so it needs to be centered. In my experience the timing marks on the pump don't make a noticeable difference and was told to leave it alone centered on the mark. Sounds like you have fuel up top but in case you haven't when ever those injector lines come off. tighten them to the pump and leave them loose on the injectors and crank till they spill diesel out all of them then tighten them down.
This little trick got me home a few times when my fuel system was plugged with a bunch of shredded paper pieces
Nice...
It's funny, my last 3b, I figgered I'd give it a flush with some seafoam. While it was idling, I pulled off the fuel line, stuck it in can of sea foam, then reconnected when it was empty.
figgered I'd get air in it for sure, but my primer pump leaked like a sieve and I didn't want to get diesel all over me if I didn't have to.
Engine didn't hesitate for a second.
jeez. Now I'm getting all nostalgic. I need another 3b.
this is the little bosch pump I was referring to.
Prime the injection pump, then prime the injectors.
Also check at No1 TDC that the valves are closed. If that checks out its an air problem.
Also, Nice work on the 040 casting (5 bearing cam 3B)
ok so I got it running and I will try and post some pictures of it when I get the time but right now am going like a madman trying to get this thing running and back on the road by Monday (Sun, Mon, are my day of this week) and just don't have the time. I just got home at 1:21 am.
I've hit a roadblock. Even thought it runs I need the throttle linkage for a 3-b in order to be able to make it work, you know properly. does anyone have one they would be willing to donate/sell/trade for something interesting.
i've used those in a pinch and they work well. I've got a pile of those also if you need a few.I haven't used it my self but I have read on mud where guys used bike brake cables... stock setup is better I'm sure
